Block Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 10:53 AM   #1
block foundation
distance between anchor bolts
gomaz is offline   Reply With Quote
Old 08-01-2011, 11:11 AM   #2
concretemasonry's Avatar
Rewards Points: 2,608
What about it? - Not much to go by or answer.
Usually, the distance between them depends on the location and code in effect and use of the structure or loads. there are also requirements for the distance to the end of whatever you are holding down or stopping from sliding.
Dick
concretemasonry is online now   Reply With Quote
Old 08-01-2011, 11:12 AM   #3
Civil Engineer
Rewards Points: 4,790
This must be a Haiku.
Distance between anchor bolts?
Have I asked a question?
Does the eagle eat fish?
Why am I here?
There is no tomorrow.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
AndyGump (08-01-2011)
Old 08-01-2011, 11:14 AM   #4
the Musigician
DangerMouse's Avatar
Imagine you walk into a room where there are hundreds of people.... you say "distance between anchor bolts". Do you truly imagine ANYone will know what the heck you are talking about? Or do you think they will care? This forum is that room. If you have a QUESTION, please learn to speak English and ask it properly. We do not read minds, and only a few of our members will even attempt to decipher what the heck you're talking about. So good luck with that.... perhaps rephrasing might help?
DM
Old 08-01-2011, 11:17 AM   #5
the Musigician
Why am I here?
Good one Daniel!
I hate razzing this guy, but I'm getting pretty tired of people doing this here.
DM
Old 08-01-2011, 04:41 PM   #6
Rewards Points: 4,656
all of the above & i don't mind any response razzing anyone who's this self-absorbed OR ignorant of forum etiquette
btw, 18' or was that inches ? ? ?
Old 08-01-2011, 05:23 PM   #7
Concrete & Masonry
Rewards Points: 582
You'll need to check your own local code, but for instance here, it's 6' max centers between bolts (hot-dipped galvanized minimum if going into ACQ treated plate) 18" max. from openings & corners, and at least 2 per wall.
As for the rest of you, carry on.............
jomama45 is offline   Reply With Quote
Old 08-01-2011, 05:35 PM   #8
Framing Contractor
Your plans should tell you that. Do you have plans?
Joe Carola
Joe Carola is offline   Reply With Quote
Concrete reinforced block foundation repair questions CCHanna05 Building & Construction 2 07-06-2010 03:57 PM
Footing for Block ontop of existing Fieldstone foundation. Concerns w/ work done.. slowjo Building & Construction 6 04-26-2009 10:17 PM
block foundation shama144 Building & Construction 5 10-27-2008 07:07 AM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 09:48 PM
Concrete Block Foundation Questions project_guy Building & Construction 1 05-09-2008 09:16 AM
