Block/Fieldstone Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 10:51 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
I'm moving a basement door that goes through a block foundation.
The foundation is fieldstone below grade and block above grade. The door is above grade. Once I get all the blocks in, I plan to rebar and grout the blocks where I can.
When I weave the new blocks into the foundation where the door used to be, should there be some kind of mechanical fastener between the fieldstone and the block?
Also, should there be a mechanical fastener horizontally between the blocks or is the mortar enough to hold everything together?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-12-2011, 05:06 PM   #2
Concrete & Masonry
Rewards Points: 620
Mortar alone should be sufficient in this situation. Applying good skills with the placement makes all the difference though. The key is to compress the mortar adequately when laying rather than doing a bunch of tuckpointing afterwards.
jomama45 is offline   Reply With Quote
Old 04-12-2011, 09:23 PM   #3
If you "toothed out" the block when you removed it, meaning you followed the path of the mortar joints and left kind of an in and out pattern with the block and didn't just cut a straight vertical line with your saw on both sides of your door your fine. You can just lay the new block in and you still keep that original staggered bond that was existing. If you just cut straight vertical lines I know an architect or engineer would make you use ties to tie the new in with the old because i've been told to do it more than once. It doesn't hurt to use ties if you just cut straight vertical lines but if you grout it solid especially where the new meets old I personally think you would be fine.
DETROIT GRIFF is offline   Reply With Quote
Old 04-13-2011, 09:14 AM   #4
I have gas!
I'll be surgically removing the blocks with a grinder so no straight lines.
For the mortor pre-mix, is type N the correct blend?
http://www.quikrete.com/ProductLines/MortarMix.asp
Also found type S:
http://www.quikrete.com/ProductLines/MasonMix.asp
Followup Edit:
Type S is required according to this video on Quikrete's website:
http://www.quikrete.com/AtHome/Video-Blockwall.asp
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
