Block And Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2009, 07:03 PM   #1
block and brick
What do you guys think is the easiest way to figure 8 in block / 4 in block and brick on a brick to grade home. Also what is the best way to tie the brick into the block?
Toolmaster is offline   Reply With Quote
Old 08-26-2009, 07:17 PM   #2
Old School
Willie T's Avatar
Square footage... brick ties.
Willie T
Old 08-29-2009, 10:35 PM   #3
Rewards Points: 95
I agree with the SQ Ft method, But using eye wire in the block wall would be better way to tie the walls together.
NJ Brickie is offline   Reply With Quote
Old 08-30-2009, 07:35 AM   #4
Remodeling Contractor
the foundation should have a ledge that is meant to support the brick.
Old 08-30-2009, 09:03 AM   #5
Concrete & Masonry
Rewards Points: 468
NJ, are you refering to Durawall?
jomama45 is online now   Reply With Quote
Old 08-30-2009, 10:24 AM   #6
Rewards Points: 95
Yes dur-o-wall with eyes.
http://www.dur-o-wal.com/a02_multi_a....html?pcid=144
Old 08-31-2009, 01:34 PM   #7
to make this clear... dura-wall is to strengthen the block walls. Brick ties is to hold the bricks to the block.
Old 08-31-2009, 01:57 PM   #8
concretemasonry's Avatar
Rewards Points: 2,566
Dur-O-Wal does really not strengthen a wall. It provides continuity and help with crack control if installed properly.
The are are many different types of Dur-O-Wal including different thicknesses, types of steel and coatings and internal wire patterns (laddur and truss).
The "eye and pintel" type is probably the most versitile. The eye is an eye on the outer edge of the longitudinal wire the is allowed to project beyond the wall face. The "pintel" is an L shaped iece the hooks into the "eye" when the brick course is laid. This allows the "pintel" to be moved vertically to adjust for the diference in mortar joint elevations. The brick is laid to a line on the finished side of the brick and pintel is in the mortar joint. As I recall there was also a "drip" bent into the pintel to allow any moisture between the wythes to be kept within the cavity and drain out of the weeps.
There is also a cheaper type (referred to as a "tab" type), but is does not allow for for vertical adjustment of irregular shapes like stone. Also there is a "tri-wall" that has 3 longitudinal rods, but no vertical adjustment for different types/sizes of masonry units.
Dick
concretemasonry is offline   Reply With Quote
Brick Ledge when using cinder block DaveMo Building & Construction 5 07-13-2011 10:46 AM
Painting Brick? Eipnvn Painting 3 05-19-2009 11:31 AM
Footing for Block ontop of existing Fieldstone foundation. Concerns w/ work done.. slowjo Building & Construction 6 04-26-2009 11:17 PM
Requirements for doorway in Brick and Cinder block sandyman720 Building & Construction 5 03-07-2007 10:48 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
