Blind Nailing 12'' Lp Smartside - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 07:59 AM   #1
pwa
blind nailing 12'' lp smartside
Hi to all, I have been blind nailing 12'' lp smartside lap siding over sheathing and am having trouble with the edges laying flat,mostly on the gable ends where the edges are even longer than 12'' because of the angled cut.Most of it feels pretty tight,can I get away with only nailing the edges?After reading a little it seem common to face nail siding over 8''.I think LP Smartside should have mention that in install directions on their website
pwa is offline   Reply With Quote
Old 08-26-2012, 08:13 AM   #2
kwikfishron's Avatar
Rewards Points: 368
You shouldn't blind nail a 12" panel.
kwikfishron is online now   Reply With Quote
Old 08-26-2012, 08:44 AM   #3
pwa
Grrreat!!! I dont have any experiene with this and was just trying to follow what I thought was the right directions, now what? I am about 2/3 done
Old 08-26-2012, 09:05 AM   #4
Rewards Points: 368
You need to find the studs and nail it off. Use a level or straight edge to mark the stud locations so you have straight nail lines.
The instructions show 2 nails per stud, one on top and another on the bottom and a few other important nailing details you should look up and know.
The Following User Says Thank You to kwikfishron For This Useful Post:
pwa (08-26-2012)
Old 08-26-2012, 09:39 AM   #5
pwa
Ok, I quess I did'nt understand the directions I have looked over them many times. Did you get that from the manufacture site? I see a heading for 8'' only and the rest of the directions dont specify.There is a heading(nailing instructions) that says to blind nail it accept for windows sills,freeze boards and horizontal trim bands.I dont even know what the the last 2 are.There no mention of widths this applies to.I am using series 38 i.e. 3/8.So its pretty clear I will need so face nailing.But do I need to nail it off every 16'' towards the bottom or can it just be nailed on the pieces not tight on the corners?
Old 08-26-2012, 09:47 AM   #6
Rewards Points: 150
Need to nail all of it, In a neat and uniform manner like previously spoken. What looks tight now wont be once a hot cold gets to it.
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
The Following User Says Thank You to Hammer450R For This Useful Post:
pwa (08-26-2012)
Old 08-26-2012, 10:03 AM   #7
Rewards Points: 368
It's the first link on THIS page.
pwa (08-26-2012)
Old 08-26-2012, 10:35 AM   #8
pwa
Getting my butt kicked, thought I knew what I was getting into,should have went with a size with less reveal Thanks for help guys
Old 08-26-2012, 11:03 AM   #9
AHH, SPANS!!!
Rewards Points: 1,166
once you find one stud in the wall you should be able to pull 16" from that stud to find the other studs in the wall, or if they framed 24" centers then 24" would be the number to pull...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
pwa (08-26-2012)
Old 08-26-2012, 11:20 AM   #10
Rewards Points: 13,446
I'd use stainless steel ring shank real siding nails.
Not going to rust, hold like crazy and have smaller heads so they do not show as much.
pwa (08-26-2012)
Old 08-26-2012, 11:20 AM   #11
pwa
yeah its just more nails that I will need to paint over to make them less noticable and they call for sealing anyway.It just can suck when its 2 steps forward and 1 back
Old 08-28-2012, 09:32 AM   #12
Rewards Points: 12
pwa, thank you for choosing LP SmartSide siding.Your finished project will undoubtedly be beautiful. Patrick
LPSmartSide is offline   Reply With Quote
Blind Nailing for Decks ? II Weeks Carpentry 15 06-15-2012 09:41 AM
Blind Nailing 8 1/4 hardiplank with 7" reveal hartkem Building & Construction 54 01-21-2012 07:43 PM
Window treatment options? bokeh Interior Decorating 13 07-04-2011 12:30 PM
Replacing Vinyl Windows w/o Nailing Fin irish Building & Construction 1 06-03-2010 10:37 AM
LP Smartside Lap Siding - Nailing Question? canyonbc Carpentry 3 01-18-2010 01:26 PM
