Blind/False Valley Vs. True Valley For Dormer - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-08-2010, 07:47 PM   #16
Hey Gary,
Do you by any chance have any close up pictures/diagram of the valley board construction (with bevel)? Sorry, I'm not entirely following your directions.
Joe
Joe1. is offline   Reply With Quote
Old 08-08-2010, 08:01 PM   #17
Framing Contractor
Originally Posted by Joe1. View Post
Hey Gary,
Joe
Joe,
You don't bevel the valley.If you want you can but there is no reason at all to do it. Your framer will show you when he puts it in. It is very simple once you see it
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-08-2010, 09:36 PM   #18
Hi Joe,
Yeah, I'm thinking it also must be one of those things you just have to see. I figured I'd be able to understand it anyway when I got to it, but at this point a regular framer will be doing it, it seems, so it doesn't really matter I guess.
Joe
Old 08-09-2010, 05:24 AM   #19
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
I just built this type of roof last summer/fall/winter. I did bevel the edge of the vb to give the sheathing something solid and flat to nail into. All the angles took a little while to figure out.
The ridge did not fall on a main-roof rafter. To carry the ridge on the main roof, I put a small header on the inside of the main roof between between the rafters.
The straws sticking up will show me where it's safe to cut holes for venting.
HTH
Blind/False valley vs. True valley for dormer-valleyboard_sm.jpg
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Need input on this open valley technique jogr Roofing/Siding 12 11-01-2011 06:49 AM
