Black Top Patching - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 12:49 PM   #1
Black top patching
I have a large (200 ft2) area that needs to be removed and repaved because of drainage problems. The blacktop is fairly new - 3 months old.
Here are my questions:
1. Should the edges of the "old" blacktop be heated with a propane torch before the repaving is done?
2. Should the edges of the "old" blacktop be treated with some sort of adhesive before the repaving is done?
Thanks, Justin
daubar is offline   Reply With Quote
Old 07-27-2011, 12:56 PM   #2
AGWhitehouse's Avatar
I'm confused...you said you're removing it but your questions pertain to it remaining...
Are you removing 200sq.ft. of a much larger driveway? If so you can saw cut a nice joint and remove the section and then patch in the pavement and create a flush cold-joint. Cold joints will crack over time as water has a chance to penetrate.
If you are going to remove the smaller area and then infill flush with a base coat and then overcoat the whole driveway, then there is a liquid that gets applied between coats to help the asphalt adhere to the layer below. No torching is required.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-27-2011, 02:43 PM   #3
Black top patching
Thanks for the quick reply.
Sorry for the confusion.
Yes, I am removing 200ft2 of a very much larger driveway.
I am then going to have the 200ft2 section re-done (this is not an overcoat) with the proper drainage.
I understand what you said about the adhesive and heating not being required.
Concerning the new flush cold-joint: Will it help to seal the joint to prevent water from getting into the joint a month or 2 after the job is complete?
Thanks, Justin
Old 07-27-2011, 03:45 PM   #4
You certainly can seal the joint. Just like they do on the roads.
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
black, white, white, black! bamaranch General DIY Discussions 5 07-04-2010 12:24 PM
Black Iron Exposed? jamiedolan Plumbing 0 08-14-2009 10:16 AM
Smoothing Joints Between Sheetrock and Plaster Without Sanding OldManMike Building & Construction 6 06-30-2009 07:42 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
