Black Strips On Wallboard Mounted On Metal Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-19-2007, 11:08 PM   #1
Unhappy
Black strips on wallboard mounted on metal studs
I have developed dark vertical strips on wall board attached to metal studs. I have been told this is due to incomplete combustion of my HVAC system but it only occurs on outside walls. Has any one expereinced this and is there a solution. Repainting only helps for a year or so.
regman is offline   Reply With Quote
Old 07-19-2007, 11:23 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Possibly due to the excessive heat flow through the steel studs creating a temperature differential than can attract or allow air borne particles to stick to the wall. In an extreme situation, you can even get moisture patterns on the walls or ceilings. - The concept is referred to as "thermal short-circuiting".
It is even more pronounced in walls or ceilings where insulation such as fiberglass is used. The effective R-value of the bulk insulation can be reduced by 20-40% in steel stud walls. The same effect occurs in wood frame walls, but not to as much a degree. Walls with a 1-2" layer of extruded foam do not exhibit the "thermal short circuiting".
concretemasonry is offline   Reply With Quote
Old 07-20-2007, 05:36 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
WOW....I did not know that....
- Build Well -
Old 07-20-2007, 10:45 AM   #4
The "R-value" of a bulk insulation is the value of the insulation itself in a laboratory. Then, it goes into the wall the wall construction and properties of the other materials can significantly change the real R-value of the wall. - In other words, R19 insulation in a wall does not give you an R19 wall (you get something less).
Different materials or closer spacing of studs have an effect. A prime example is 6" metal studs @ 12" O.C. - Sort of reminds me of a radiator.
It even get more complicated when you can get big insulation credit for heavier walls that increase the effective insulating value of a wall in real life subjected to annual and/or daily temperature cycles.
Old 07-20-2007, 11:07 PM   #5
remodeling pro
Concretemasonry has it nailed here.The stripes are a direct result of moisture from condensation caused by the thermal bridging of the metal framing members.
troubleseeker is offline   Reply With Quote
Plasma Mount into Metal Studs davewolfs Home Theater 24 05-21-2009 09:23 AM
Black Metal Roof??? Goat66 Roofing/Siding 2 01-31-2007 11:58 AM
metal studs to build up attic floor Airborne180 Carpentry 6 12-13-2006 05:02 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 05:31 PM
