Birdsmouth Rafter Cut - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 11:01 AM   #31
Does it All
http://www.construction-resource.com...roof-frame.php
best answer... "GOOGLE IT"
Artic50000 is offline   Reply With Quote
Old 01-20-2012, 12:25 PM   #32
Rewards Points: 506
If you want to read some more there is an active thread on contractortalk.com which discusses the absence of birdsmouth notches in rafters with tails. This alternative method allows the rafter rest on bearing blocks which are sistered to the ceiling joists. Interesting concept, I guess. The seat cut is therefore not level, but matches the roof slope.
As always, don't expect to participate in the discussion unless you can demonstrate your existence as a professional contractor.
jlmran is offline   Reply With Quote
Old 01-22-2012, 01:50 AM   #33
Rewards Points: 214
Originally Posted by Joe Carola View Post
Some full time framers do this but they use a saw that has a swing table on it from Big Foot tools that cuts up to 75....the saw is actually called Big Foot.
There was also a specialized tool for cutting birds mouths. Worm drive circular saw with a wide table and about a 4" wide set of stacked dado blades. You lined up your rafters, set tha angle on the table and hogged out the entire birdsmouth all at once.
It was kind of a scary looking rig.
A Squared is offline   Reply With Quote
Hip rafter birdsmouth jlmran Carpentry 10 01-24-2011 05:30 PM
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 10:26 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
Hip, common rafter birdsmouth depth? johnd393 Building & Construction 25 04-28-2010 09:04 AM
rafter birdsmouth and wall sheathing ??? Clutchcargo Building & Construction 4 07-10-2009 08:47 PM
