Birdsmouth Rafter Cut - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 06:56 AM   #1
birdsmouth rafter cut
I am fairly new to rafter cutting, but i have always marked my first common and cut it and used it as my pattern. cutting each rafter one at a time. i recently watched a roof framing video where they were gang cutting the birdsmouths. 12 on 12 pitch with a skillsaw on a 45 degree angle for both cuts. my question is how did he figure how far apart to make those two cuts. if anyone knows this can you also explain diffrent pitch roofs too
CJB143 is offline   Reply With Quote
Old 01-16-2012, 07:27 AM   #2
Framing squares come with an instruction manual. This will tell how to do the birdsmouth for any set of roof pitches. Too much info to put here.
Old 01-16-2012, 07:50 AM   #3
i understand how to do birdsmouth cuts for common and hip rafters. its just gang cutting all.
Old 01-16-2012, 07:53 AM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Like Bill said, it would take a long description and pictures to make you understand.
Just keep cutting them the way you are.
(they probably had a bunch standing together on edge with their saw set on a 45° if it was a 12/12 they were cutting. Measure the depth of one you already cut and set blade depth accordingly).
titanoman is offline   Reply With Quote
Old 01-16-2012, 10:16 AM   #5
Retired carpenter
Length of plumb cut (or level cut) times the square root of two.
Unless you have a saw that can tilt more than 45 degrees, there's no point.
abracaboom is offline   Reply With Quote
Old 01-16-2012, 10:40 AM   #6
i have a worm drive skil that goes to 53 degrees... i think that is a 16/12
Old 01-16-2012, 11:06 AM   #7
Disabled wood vet
titanoman's Avatar
Length of plumb cut times the square root of two?
Makes zero sense to this roof master.
Old 01-16-2012, 04:53 PM   #8
Retired carpenter
I would still cut them one at a time, if you care a bit about precision.
The "no calculations" method to know the distance between the two lines would be to lay out the birdsmouth in one rafter as always, and use a tape measure to measure the distance between the lines.
Old 01-16-2012, 04:55 PM   #9
Retired carpenter
Makes zero since to this roof master.
With what do you associate the square root of two?
Old 01-16-2012, 05:17 PM   #10
Old School
Willie T's Avatar
Guys...... Root 2 is a math joke.
Willie T
Old 01-16-2012, 05:56 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Made me do a little head scratchin there, but that will only work on a 12/12 pitch, oh wait it will work on a 14/14 pitch won't it.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 01-16-2012, 06:15 PM   #12
Framing Contractor
Once you mark your birdsmouth ....you have both marks on the bottom edge of the rafter pattern which represents the seatcut and heel cut. Rack you bench with the rafters on edge w/bottoms facing up and take the pattern with the birdsmouth and mark both sides of the rack with the two birdsmouth marks...(seatcut and heel)and snap the two lines. Those are your lines that you will cut.
Some full time framers do this but they use a saw that has a swing table on it from Big Foot tools that cuts up to 75°....the saw is actually called Big Foot.
It's easy when the pitch is 12/12 because both cuts are 45°. When the pitch is 5/12 for example..the heel cut would be 22.62° and the seatcut would be 67.38°. This is where the bigfoot swingtable saw comes in. Here is a link to their website.
http://bigfootsaws.com/swing_tables.html
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-16-2012, 06:15 PM   #13
joed's Avatar
Rewards Points: 11,598
If you know how to mark a single birds mouth then try this. Mark a rafter on the side like normal. Bring the mark around the side to the edge using your square. No need to actually measure it at all.
The Following User Says Thank You to joed For This Useful Post:
kwikfishron (01-16-2012)
Old 01-16-2012, 06:49 PM   #14
Framing Contractor
Here are the two marks that you use to gang cut on the rack with the bottom of the rafters facing up. I used a 5/12 pitch for the example.
Joe Carola
Old 01-16-2012, 07:48 PM   #15
Disabled wood vet
titanoman's Avatar
What are you talking about? Is that a real question or are you making jokes that are going over my head?
Hip rafter birdsmouth jlmran Carpentry 10 01-24-2011 06:30 PM
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 11:26 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 08:55 PM
Hip, common rafter birdsmouth depth? johnd393 Building & Construction 25 04-28-2010 10:04 AM
rafter birdsmouth and wall sheathing ??? Clutchcargo Building & Construction 4 07-10-2009 09:47 PM
