Birds In My Walls! Need To Repair... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 09:35 AM   #1
Rewards Points: 152
Birds in my walls! Need to repair...
The cat was taking particular interest in one outside wall the other day, listened close and heard some clattering and chirping. Took a look outside and there was a hole in the wall right beside the electrical mast
Tried the attic, no dice. Went up the ladder with a little flexible wire camera (like for looking in sewers) and found 2 birds. Managed to get them out after poking them for a while with the camera and screwed some wood over top.
Looking in the hole from the outside, I can see the back side of the drywall. The vapor barrier, insulation, sheeting and siding is all gone. I was thinking about taking out a chunk of drywall and rebuilding from inside the house (so I don't have to be 25' up a ladder trying to fix it).
Mentioned this to a finishing carpenter at work and he suggested a can of spray foam instead. Said it'll fill the void right up and act as a vapor barrier as well.
Any suggestions?
Thanks!
burnt03 is online now   Reply With Quote
Old 02-06-2010, 10:23 AM   #2
the Musigician
DangerMouse's Avatar
I'd go with the spray foam as well.
DM
Old 02-06-2010, 07:29 PM   #3
King Construction Inc.
spray foam would work perfect... you can insulate and fix the hole at the same time without cutting into sheetrock and going that route, much easyer fix
nking is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Help please...quick. Kilz dripping off walls jenllo Painting 7 01-24-2010 07:40 PM
Best way to repair concrete retaining walls? ohman Landscaping & Lawn Care 2 06-25-2009 11:45 AM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 03:07 PM
