Old 07-05-2012, 10:38 AM   #1
bigger window installation
trying to install a bigger window in a bedroom located in on of the house corners ( ranch, one level house build in 1959), while taking off the dry wall, find out that there is a 1x4 extra support runs from the top corner of the wall all way to the floor in 45 angel, attached on the side of the studs. the bigger window will be in the way . what necessary steps should be taken?
amerali is offline   Reply With Quote
Old 07-05-2012, 10:50 AM   #2
Framing Contractor
That brace will be cut out when you install your new header.
Joe Carola
Joe Carola is offline   Reply With Quote
couple of window installation questions wengang1 Carpentry 5 10-19-2010 08:09 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Window well installation gruntman Building & Construction 6 09-26-2009 06:54 PM
New Construction Window Installation SanDiego Building & Construction 1 06-16-2009 12:28 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
