"Bigfoot" Footings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2008, 12:45 AM   #1
Weekend Butcher
"Bigfoot" footings
I was wondering if anyone had any experience with bigfoot footings. They attach to the sonotube and enable you to pour both the footing and the piers all at once. Where i live the footings need to be 24"x24"x6" and the piers to be 18" and 8" above grade. I feel these would make the job go a little faster and alieviate the need for 2 separate pours. Any ideas/guesses if these meet code. BTW this is for a 14"x14" deck
thanks
drewid153 is offline   Reply With Quote
Old 06-12-2008, 05:19 AM   #2
code i don't know but if i were using your method for my new deck, it wouldn't bother me a bit,,, i like the things - either flexible or paper.
yes.itsconcrete is offline   Reply With Quote
Old 06-12-2008, 08:18 AM   #3
Rewards Points: 154
Check their website but I believe only the BF36 will fit an 18" tube, which means you must dig at least a 36" diameter hole. That's one huge footing for a deck support.
ovahimba is offline   Reply With Quote
Old 06-12-2008, 09:35 AM   #4
Weekend Butcher
Sorry I wasnt clear the piers have to be 10" diameter and 18" below grade and 8" above. Hope fully the do a smaller version......
Help with footings etc Ramjak Building & Construction 1 04-06-2008 08:45 PM
footings vs pylons smarbaga Building & Construction 1 03-26-2008 09:53 PM
Footings? sandyman720 Building & Construction 1 05-30-2007 12:22 PM
Concrete shed footings in a marsh/wetland? tigerbalm2424 Building & Construction 11 03-27-2007 06:37 PM
Adding a room, footings for all walls, or just new exterior? mt232 Building & Construction 2 09-25-2006 06:55 PM
