Big Gap Bwtn Foundation And Sill Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-20-2011, 10:29 PM   #1
Rewards Points: 113
big gap bwtn foundation and sill plate
I just had someone redid 20 ft of foundation (24 inches deep.) House was shored up, sunk foundation was cut and removed and new foundation was poured about 5 days.
Now I removed the form and discovered that the some spaces underneath the sill plate have some really big gap pls see pics. what can I do?
thanks in advance!!!
big gap bwtn foundation and sill plate-found1.jpg   big gap bwtn foundation and sill plate-found2.jpg
oldhouse49 is offline   Reply With Quote
Old 10-21-2011, 07:29 AM   #2
Rewards Points: 1,216
Non shrinkable grout or foam. Wish those plates were pressure treated?
COLDIRON is offline   Reply With Quote
Old 10-21-2011, 07:56 AM   #3
kwikfishron's Avatar
Rewards Points: 188
Those plates are PT, in fact that’s about as good as PT gets. We build dock frames with that stuff.
Way more stable than that yellow pine crap I’ve been introduced too since I left the Left Coast.
kwikfishron is online now   Reply With Quote
Old 10-21-2011, 08:19 AM   #4
Rewards Points: 113
yes, those were PT.
so just patch with quikrete?
right now there're temporary shoring supporting this section of the wall, should i remove the shoring before applying the quikrete or after ?
should i seal the exposed concrete with some concrete sealer afterwards?
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 11:33 PM
Replace Sill Plate to Basement Block Wall - No anchor bolts DoItMyselfToo Building & Construction 4 09-10-2011 04:07 PM
Foundation anchor bolts and sill plate question dwoloz Building & Construction 7 05-17-2011 08:17 AM
sill plate repair over block foundation MARLE Building & Construction 14 05-04-2009 09:03 PM
Half Lap Sill Plate Join Clutchcargo Building & Construction 3 09-05-2008 04:07 PM
