Big Foot Footings - How Many? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2008, 11:02 AM   #1
Rewards Points: 93
Big Foot Footings - How many?
I just called BigFoot systems and the smallest footing system they sell is a BF-20 which is 20" round. I really only need 16", but I'll go with this because it is easier than building my own footings and will save me time.
They will ship free if I order 6 or more.
Here is my question: I have attached a drawing of my 32x10 porch. I am building on 2x8 lumber. The porch will be built on clay soil. Do I really need BF-20 footings at every location that I have noted on my drawing? It's probably not something you all might be able to answer, I do understand that, but if you could give me reasons why I would need the support rather than just going with a 12" tube on the footings closest to the foundation walls.
FYI, decks.com recommends the following: I assumed this is a minimum, because the deck will also be supporting a roof.
Beams:Southern Pine:2-2x6
Corner Footings:Clay:9" diameter
Intermediate Footings:Clay:13" diameter
my5sons is offline   Reply With Quote
Old 11-24-2008, 11:07 AM   #2
Registered User
Termite's Avatar
You really need to call the codes department in the city you live in to determine what the local codes and requirements are. They vary regionally and from city to city, mostly because of frost issues and soil bearing capacities.
You may find that proprietary footing systems are a big waste of money.
Old 11-24-2008, 11:07 AM   #3
Rewards Points: 93
Here is a pic of my house...
This is a photo of the house when the contractor was trying to build it. I tore it all down and am starting from scratch, but at least you can see the 2 roofs that it will tie into.
Old 11-24-2008, 11:10 AM   #4
Rewards Points: 93
Thanks for the reply. I am not interested in building to the minimum standards of code. I plan on living in this house for a long time, and don't want the added stress of replacing things later. The code enforcement here is a joke. 12 " is the frost line (great for me), I am digging down 2 feet and putting 6" of gravel. They only require 12" round footings. They don't even care that I am on clay soil, the code guy already passed the other guys footings, and I dug them out. I'm thinking he used 1 - 60lb bag. That may be good for a deck, but I don't believe they are ok for a porch with gable roof spanning 30 + feet.
Old 11-24-2008, 09:01 PM   #5
You may want to have a local structural engineer design and inspect the footings for you. Cheap insurance.
samjack is offline   Reply With Quote
footings vs pylons smarbaga Building & Construction 1 03-26-2008 09:53 PM
Cost per square foot -- very small addition rubeng Building & Construction 7 12-13-2007 12:41 AM
Over 8 Foot Wall - Method of Applying Sheathing... MoparAutoworks Building & Construction 14 08-20-2006 07:38 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
