Between Insulation And Foundation Exterior Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-07-2008, 05:17 PM   #1
Between insulation and foundation exterior walls
Just ripped apart old paneling from a basement room in order to install drywall. I pulled back the insulation and discovered just the concrete foundation. Should there not be something between the foundation and the insulation? Some kind of membrane on tarpaper?. I live in a fairly dry climate so humidity is not an issue in the basement. (Oroville, WA) Or is the tarpaper only installed to the outside of the concrete foundation walls?
sithappens is offline   Reply With Quote
Old 04-07-2008, 07:07 PM   #2
you do not want anything between the livable air space and the exterior concrete that will trap moisture vapors. plastic or tar paper are not brathable materials and you will have mold
jason h is offline   Reply With Quote
Old 04-08-2008, 12:05 PM   #3
Rewards Points: 1,910
Did you find any problem that suggests that the installation wasn't adequate (mold, wet insulation, water stains, etc.) If not then I'd say the installation was ok.
foundation question. Gebby Building & Construction 6 02-29-2008 09:14 AM
How important is plastic vapor barrier on foundation wall? slatergrl Remodeling 5 02-18-2008 12:49 PM
Cantilevered floor insulation rickswa Building & Construction 5 01-02-2008 12:08 AM
Crawlspace insulation reccomendation Gus Building & Construction 3 12-29-2007 11:23 AM
