Which Is A Better Sound Insulator? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-21-2009, 08:30 AM   #1
motivator
Speedball's Avatar
Which is a better sound insulator?
2" foam board or regular paper faced fiberglass insulation. I need to insulate an interior wall separating the living room from the laundry room and the drywall is off the laundry room.
I was going to use fiberglass but last night got the idea to use foam board.
Any idea?....Thanks.
............Enjoy...Pat
Speedball is offline   Reply With Quote
Old 03-21-2009, 10:19 AM   #2
Rewards Points: 602
Fiberglass insulation is about as good for sound proofing as having nothing at all. Here are a few websites to look at:
http://www.soundproofing101.com/
http://www.glacierbay.com/insulation_ultradb.asp
http://www.constructionresources.com...e/acoustic.asp
http://www.acousticsfirst.com/vinyl.htm
http://www.extremesoundproofing.com/...cs/basics.html
http://www.soundprooffoam.com/
http://www.buildingscience.com
Hope this helps. Also, do a search on this forum for sound proofing. I know there are some good threads that talk about it. That's how I found the websites listed above.
gma2rjc is offline   Reply With Quote
Old 03-21-2009, 12:11 PM   #3
motivator
Speedball's Avatar
Just stopped by for a minute.........
Thank you so much for those links, I have some reading to do when I get back from working on the house.
Old 03-21-2009, 12:30 PM   #4
Remodeling Contractor
Quietrock was not mentioned. It is a sound proofing panel that will offer more sound deadening than the other mentioned sites.
Old 03-22-2009, 10:24 AM   #5
motivator
Speedball's Avatar
Mmmmmm, QuietRock.
Old 03-22-2009, 02:43 PM   #6
Originally Posted by Speedball View Post
Mmmmmm, QuietRock.
Type? Should be Shhhh! QuietRock
constant running water sound gmk2008 Plumbing 9 11-11-2008 08:22 PM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 05:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 07:36 AM
