Better - Gravel Or Paver Base For Cement Slab ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 01:15 PM   #1
Better - gravel or paver base for cement slab ?
does it make a difference to pour outdoor cement slab (for a shed) over a compacted "Step 1" paver base or gravel ? The reason is I have quite a few bags of Step 1 Paver Base available but not gravel.
timcsi is offline   Reply With Quote
Old 08-19-2011, 09:26 PM   #2
Rewards Points: 1,092
whatever you put down should be compacted if settling is an issue. a small shed w/out pipes and wires penetrating it needs little help if your ground has any guts. what will settling hurt? nothing? then don't be too worried about what you use.
gravel under slab? ptcamaro Building & Construction 3 08-20-2009 08:15 AM
Paver Patio Prep, base amounts bartic Landscaping & Lawn Care 4 05-29-2008 09:01 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
conc slab inside/under a enclosed metal carport blthomas Building & Construction 3 02-01-2008 09:18 AM
Pouring a concrete slab - Do I need a 4" gravel base? tokuzumi Building & Construction 2 11-27-2007 07:40 PM
