Which Is Better To Fasten A 3x3 Aluminum Column To A Concrete Slab ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 01:10 PM   #1
which is better to fasten a 3x3 aluminum column to a concrete slab ?
getting a composite roof overhang to my back patio done. One company says they fasten with :
-3/8 stainless wedge anchors
another company says they will fasten the columns to the concrete using :
-tapcons
is there really a big difference between the two ? I am in South Florida and we are in hurricane country.
Thanks...
ps...the roof overhang will look like this :
filo74 is offline   Reply With Quote
Old 04-28-2010, 07:28 PM   #2
remodeling pro
I would use the wedge anchors. My experience with Tapcons had been more frustrating than not. The diameter of the drilled hole is crucial to their holding power. Even when using the proper Tapcon bit, the least amount of drift or wobble weakens the connection consideably, often resulting in a stripped out hole.
troubleseeker is offline   Reply With Quote
Old 04-28-2010, 07:55 PM   #3
Man...what should I do. The price from contracter # 1 that uses the wedge anchors to fasten the columns to the slab is 4K. The price from contracter # 2 that uses the tapcons is 3,280. what should one do...
Old 04-29-2010, 09:28 AM   #4
Tapcons or wedge anchors to secure aluminum columns to concrete slab for patio overha
-tapcons
Thanks...
Old 04-29-2010, 10:11 AM   #5
Threads on same subject merged
Please only start one thread on an issue
Old 04-29-2010, 07:53 PM   #6
remodeling pro
Tell the less expensive contractor that you like his proposal, but want the roof anchored with wedge anchors instead of Tapcons. The worst he can do is tell you that he wants to charge you a few $ more because the wedge anchors cost a little more. If the $ difference is reasonable and you are Ok with everything else, you are still ahead on the price. If I were in his position, I would just agree without any $ mention; pretty absured to lose a job over such an insignificant cost item. If he is quoting his price so close that such a few dollars matters, I'd worry about if he was going to be in business long enogh to solve any warranty problems anyway.
The Following User Says Thank You to troubleseeker For This Useful Post:
oh'mike (04-30-2010)
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 05:56 AM
How to install conduit in concrete slab mthabault Electrical 4 02-24-2010 10:57 AM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 10:50 AM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 01:11 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
