The Best Wood For An Outdoor Fence? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 12:41 PM   #1
Rewards Points: 212
The best wood for an outdoor fence?
I would like to have an outdoor fence installed and would like to find out the best wood for this would be. I thought Cedar would be the best but not sure.
How expensive is cedar compared to Cypress, which my contractor seems to like.
imola ghost is offline   Reply With Quote
Old 04-18-2009, 02:54 PM   #2
knewbie
curapa's Avatar
In my area Cedar and Cypress are roughly the same cost. Are you set on not using pressure treated, as it is definitely the most cost efficient.
I do not have a problem using Cedar or Cypress on the custom fences I build, but for your average run of the mill fence I use pressure treated.
ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 04-18-2009, 05:53 PM   #3
Rewards Points: 212
I am in Jacksonville, Florida so it should be about the same price here. Would you recommend cedar over cypress?
I don't mind having to do a little up keep on either one, I just want the best wood for the job.
Old 04-18-2009, 07:33 PM   #4
knewbie
curapa's Avatar
I like Cedar because of the pretty smell .
Old 04-18-2009, 09:07 PM   #5
Rewards Points: 212
I need to price out Cedar shadow box fences around here.
About how much do you or would you charge for a job like this:
144' of 8'x6' cedar shadow box fence (picture framed)
62' of 8'x3' cedar shadow box fence
2 cedar gates
using 6"x6" posts
Another question:
If I use cedar for the fence, should I use cedar for the 6"x6" posts that are holding the fence up or do you use pressure treated lumber?
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
