Best Way To Wrap Porch Beam In Aluminum - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 10:39 PM   #1
Best way to wrap porch beam in aluminum
I currently have aluminum fascia installed on the front facing portion of the beams on my porch. The bottom and back facing portion of the beams are not covered and are just wood with peeling paint. I would like to cover everything using aluminum trim coil but I am not sure what the most common practice is to cover the beam in this situation. I would like to leave the existing fascia alone and just cover the bottom and back. I was thinking of bending a piece of trim coil into an L shape and letting the existing fascia overlap it. I am wondering if this is the most common practice or if there is a better way. See pictures below:
timw88 is offline   Reply With Quote
Old 06-12-2009, 12:16 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
would look better if you can slide your new wrap under the 1'' return of the old fascia,i would think about filling in that space with wood
Tom Struble is offline   Reply With Quote
Old 06-12-2009, 07:40 AM   #3
Man of many hats
wrangler's Avatar
Rewards Points: 354
The way I read his post, that's what he's planning on doing. And that should work fine. The wood appears to be cedar and not pressure treated, so I'd say go for it.
Man of many hats
wrangler is offline   Reply With Quote
Old 06-12-2009, 09:51 AM   #4
I do plan on sliding the new piece under the return from the front part of the fascia.
Old 06-12-2009, 10:23 AM   #5
yes.. i see that now thanks
Old 06-12-2009, 10:51 AM   #6
Rewards Points: 5,336
I would slide the aluminum up behind the gutter as much as possible. Ideally, it should go all the way up, behind the drip edge.
Ron
Old 06-12-2009, 11:05 AM   #7
if you want since its in a protected area you can install the soffit first, space panel properly then when you measure the beam for the wrap add a 1-1/4'' bend at the proper angle to cover the soffit edge,you can eliminate the j channel this way.Depending on the soffit profile you may have to install a 2x2 piece of bent aluminum where the beam and ply ceiling meet first,more complicated but what most pro's will do
Why is my aluminum wrap around my windows pulling away? Kl483@yahoo.com General DIY Discussions 5 04-21-2009 06:04 AM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
any instructions on how to install aluminum porch enclosure? brisk Building & Construction 2 12-14-2007 07:01 PM
how to figure wrap around porch roof?? What have I done Building & Construction 1 07-24-2006 01:43 AM
