Best Way To Support 4 Upright Plywood Sheets (to Serve As Walls)? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 05:29 AM   #1
Best way to support 4 upright plywood sheets (to serve as walls)?
I'm going to be getting 30 chicks in a few days and need a place to put them until they get big enough to go in with the rest outside. My plan is pretty basic: put a tarp down in the spare bedroom, cut 4 sheets of plywood to the right size, put the 4 plywood sheets upright around the four corners of the tarp to serve as walls (think of a box with no bottom or top), staple the tarp's edges to the plywood halfway up on all sides (so nothing spills out onto the floor) then put shavings/food/water/heat lamp/the chicks in there. Oh, and lay a sheet of chicken wire over the top of the whole thing.
Now, I've never built anything before in my life so bear with me, but what would be a good way to keep those four sheets of plywood upright and in place? I was thinking of lining both sides of all 4 sheets with cinder blocks but so far that's the best I've got. Doesn't need to be anything fancy, this will only be temporary (3 weeks or so) then it's all coming down again.
Any ideas would be appreciated!
joss88 is offline   Reply With Quote
Old 07-19-2010, 06:22 AM   #2
Rewards Points: 22
I would put a 2x2 (or 2x4, if you don't want to spend time ripping them), on end, in each corner, same length as your side will be tall, and attach the plywood to them with 1-1/2" or 1-5/8" long drywall screws.
Old 07-19-2010, 09:05 AM   #3
Framing Contractor
Nail them together at each corner and they won't go anywhere.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-19-2010, 10:08 AM   #4
Rewards Points: 5,336
They sell angle brackets. Put 2 in each corner with some screws.
Ron
Old 07-19-2010, 11:22 AM   #5
I second the 2x4 inside each corner. Attach to ends of two sides, and then fold up and attach the others.
If the chicks can't jump higher than 2 feet, You might be able to get away with (2) sheets of 5/8 ripped in half, and (1) 2x4x8 cut into quarters.
Stillwerkin is offline   Reply With Quote
Old 07-19-2010, 08:34 PM   #6
Registered User
Rewards Points: 4,902
Screw (pre-drill) some 1x2 on the top and bottom (inside) corners a couple of feet out, diagonally to hold in check.
Be safe, Gary
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
plywood walls autx790 Building & Construction 6 09-10-2009 10:19 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
IRC 404 Basement walls lateral support? bjr23 Building & Construction 2 07-26-2007 10:07 AM
Required support for wiring in walls? leonsphinx Electrical 5 02-23-2007 07:25 AM
