Best Way To Remove Nails In Concrete Block - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 09:40 AM   #1
Rewards Points: 640
best way to remove nails in concrete block
I took off a bunch of furring strips so I could build a true 2x4 wall in front of a concrete block wall, but now there is 4 nails per strip left in the block, what is the best way to remove these? or at least get rid of the part that is sticking out?
BlueBSH is offline   Reply With Quote
Old 07-08-2011, 10:26 AM   #2
Rewards Points: 256
Big pry bar- Will probably cause chipping though
Angle Grinder
michaelcherr is offline   Reply With Quote
Old 07-08-2011, 11:31 AM   #3
Rewards Points: 257
angle grinder/cut off wheel. will make quick work of them.
silky is offline   Reply With Quote
Old 07-08-2011, 11:41 AM   #4
Architect / Carpenter
You may also try knocking them back and forth with a hammer until they loosen up enough to pull them out - or they break off at the wall. That may cause some minor chipping as well though.
carpitect is offline   Reply With Quote
Old 07-08-2011, 11:42 AM   #5
Rewards Points: 640
might go out and buy an angle grinder tonight and try that, and certain type of disc's that would be best for this? just a metal cutting disc?
Old 07-08-2011, 11:50 AM   #6
Rewards Points: 256
Standard metal cutting disk.
Get an angle grinder in your tool arsenol, you will thank yourself.
I went along time without one, now that I bought one (now several) I use it frequently.
The Following 2 Users Say Thank You to michaelcherr For This Useful Post:
Nick DIY (07-08-2011), oh'mike (07-11-2011)
Old 07-08-2011, 11:51 AM   #7
joed's Avatar
Rewards Points: 12,000
Thin (.040) cutting disk would be the best.
Old 07-08-2011, 11:52 AM   #8
Rewards Points: 640
thanks guys, hopefully will get to try this out tonight and hope it goes well and fast
Old 07-08-2011, 11:59 AM   #9
Rewards Points: 459
Definitely agree with this. Used to use a recip saw for nails and thought it worked pretty good, but the grinder blows right through them and is far more controllable.
Nick DIY is offline   Reply With Quote
Old 07-08-2011, 12:01 PM   #10
Rewards Points: 640
I tried a recip saw already, hated it way to slow for me
Old 07-08-2011, 12:06 PM   #11
Rewards Points: 257
it's just a really thing disk. It doesn't have the rought grooves on the ont he flat part like a grinding disk does.
Old 07-08-2011, 12:07 PM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
If they are cut concrete nails they will break off instead of bend. I have an old diamond tile cutting disk on my grinder and it cuts nails or anything else great.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 07-11-2011, 04:55 PM   #13
Rewards Points: 640
to make it go faster I used a cutting disc to cut a groove in the nail, then two taps of a hammer it broke off right at the slit, saved time grinding, about 5 seconds a nail to remove, major speed improvement over a recip saw or crow bar
Old 07-11-2011, 05:05 PM   #14
DIY staff
Rewards Points: 7,174
I used a diamond blade to slice through a 4" cast iron drain pipe once--It didn't seem to hurt the thing at all.
Old 07-11-2011, 05:26 PM   #15
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
Mike, I have used the old diamond disk to sharpen my lawn mower blades also.
One strange thing I did a few years back was with a drimmel. I had a dozer and I had to take the track off to get to the bull gear in the final drive. I didn't have my grinder there so I use a metal cutting disk on my drimmel to cut the wield on the pin so I could get the track off, worked like a charm.
Jim
Last edited by BigJim; 07-11-2011 at 05:39 PM. Reason: To make paragraphs in the post
Remove mastic/adhesive from concrete? FixyChik Flooring 2 03-19-2011 10:18 AM
Cold air coming through joist holes in concrete block foundation. Ptron Building & Construction 2 01-30-2011 05:29 PM
Concrete reinforced block foundation repair questions CCHanna05 Building & Construction 2 07-06-2010 04:57 PM
Drilling in concrete block? Gary Sutherland General DIY Discussions 2 05-03-2010 10:37 AM
Question on hanging new door in concrete block wall dave11 Carpentry 7 11-12-2009 08:21 PM
