Best Way To Notch Studs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-05-2007, 10:51 AM   #1
Rewards Points: 152
Best way to notch studs?
What is the best way to cut a notch out of a wall stud?
sandyman720 is offline   Reply With Quote
Old 09-05-2007, 11:11 AM   #2
Rewards Points: 264
Make two cuts the length of the notch you need, then hit the waste with a hammer. Due to the grain direction, it usually comes out pretty clean. If not, clean with a chisel.
Jeekinz is offline   Reply With Quote
Old 09-05-2007, 03:17 PM   #3
How big of a notch? 2x4 or 2x6 stud?
bonawizer is offline   Reply With Quote
Old 09-05-2007, 09:23 PM   #4
Rewards Points: 152
2x4 studs
Old 09-06-2007, 10:44 AM   #5
i've seen a portable machine that can do it but that is usually overkill except for really big projects. i would go with the cut, hammer, chisel way
timmy is offline   Reply With Quote
Old 09-06-2007, 05:37 PM   #6
Remodeler
MinConst's Avatar
This works well!
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-06-2007, 06:29 PM   #7
Extreme DIY'r Adk's, NY
Rewards Points: 272
Not sure why you're notching studs... but if it's to run wiring or plumbing you should run a metal cover plate over the notch afterwards to avoid nailing through it later. They sell these (cheap) but Ive made them out of scrap (expensive) in a pinch also.
crecore is offline   Reply With Quote
Jack Studs Clutchcargo Building & Construction 7 09-06-2007 06:10 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 03:48 PM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 04:31 PM
