Best Way To Level A Wall On Sloped Concrete? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-13-2010, 07:59 AM   #1
Best way to level a wall on sloped concrete?
I am building a small closet in my garage as shown in the red in the attachment; room will roughly be 4 foot by 4 foot. The issue is that the concrete floor has a slope towards the door that is probably 1.5-2 inches over the 4 foot span. Looking for ideas on the best way to level out the wall. I assume I want to correct the slope in the treated sill, but not really sure what is the best way. Thanks for your help in advance.
TANC is offline   Reply With Quote
Old 07-13-2010, 08:25 AM   #2
kwikfishron's Avatar
Rewards Points: 418
You just have to stick frame it. Attach your top and bottom plates then measure each stud to fit.
kwikfishron is offline   Reply With Quote
Old 07-13-2010, 12:08 PM   #3
What a nightmare with beveled cuts.. . .I was hoping that there might be a "shim" type solution that would allow me to build a standard wall with a modified sill.
Old 07-13-2010, 12:53 PM   #4
Newbie Bill
Rewards Points: 520
I don't think you have to bevel the cuts, although you could if you wanted to. Just measure each stud.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 07-13-2010, 01:36 PM   #5
47_47's Avatar
Rewards Points: 50
I'm with Bill, with a 2" drop over 4' you are only talking about a 2 difference from 90.
47_47 is offline   Reply With Quote
Old 07-13-2010, 02:52 PM   #6
Framing Contractor
A nightmare with a 4' wall?. As mentioned it would be 2 degrees at best. Shimming would be unnecessary work and a waste of time compared to cutting the studs with a 2 degree bevel.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-13-2010, 02:58 PM   #7
Okay, thanks guys. Will give it a shot and see how it works out.
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Plaster over Concrete Sheet Wall? bk412 Drywall & Plaster 1 06-17-2010 09:10 PM
Concrete wall SRFGirl Remodeling 0 06-01-2010 09:26 AM
How to get a level floor out of one that's part concrete and part wood Songbird Flooring 5 01-22-2009 11:24 PM
Concrete Wall Structural Strength geiser Building & Construction 2 03-11-2008 10:09 AM
