-   -   Best way to insulate around a breaker box? (http://www.diychatroom.com/f19/best-way-insulate-around-breaker-box-4773/)
Chip718 11-12-2006 04:13 PM
Hi. I hope that someone can give me some advice.
We just moved into a home where half the garage was closed off and made into a room. There is a small closet in that room, maybe 6 feet high, It is that short because the garage door rolls up over it. I discovered that the walls have been insulated but the ceiling of the closet has not and the room gets really cold. I want to insulate the ceiling, but insides that closet is a circuit breaker box. If I go into the garage and look at the ceiling I can see the electrical cables and the top of the box. There are also some gaps around the box that I can fit my fingerss through that go right into that closet. Can. someone please recommend the best way to insulate around the box? Thanks fro any tips.
AtlanticWBConst. 11-13-2006 07:15 AM
Insulate away...with the same insulation you have in other parts of your home's ceilings (R-30?)
You see, your wiring and your fuse box should be all connected properly, nice and tightly done, with no worries of any sparks (you seem to be concerned about that).
If that were the case, if there were danger of this, every other piece of material around it would also be in danger of ignition as well.
You can put your insulation right up next to the wiring and next to the box with no problems. In fact, that is how the rest of your house is done (directly around all your wiring and your electrical outlet boxes and light switches and their connection points, in your outside walls)...
Good luck with those drafts...
Chip718 11-13-2006 11:58 AM
Thanks for the reply. I appreciate it.
AllGoNoShow 11-13-2006 03:41 PM
For small cracks like where wires go through walls to unheated spaces, I am especially found of using that aerosal can foam sealant and then putting regular fiberglass insulation over it for extra insulation.
Chip718 11-14-2006 05:09 PM
Hello again. R-30 insulation was mentioned in an earlier post. I just check the insulation in my house and it read R13-18. Is that ok?
AtlanticWBConst. 11-15-2006 10:28 PM
R-30 is good for ceilings.
R-13 (2x4 framing) to R-19 (2x6 framing) is good for walls.
