Best Way To Form The Slope In A Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 07:56 PM   #1
Rewards Points: 117
best way to form the slope in a patio
I need to crown my patio so about 1/3rd of the length slopes differently tha the rest.
This is to accommodate the side that joins my driveway, which slopes toward the street whereas the patio would normally slope toward the yard.
How does one build the form that is relatively level and then needs to start sloping downward?
28x17'. The 17' runs house-to-yard. The 28' runs driveway to yard, from the the left.
I have it graded to slope from house to yard, but the driveway goes the opposite, slightly.
I didn't want it all draining left to the driveway (long patio) so i thought i'd have it be left-to-right nearly level (sloping house to yard) then break downward to the driveway to match its slope.
thoughts on how to keep the tops of the forms from having gaps?
new to this.
Dornier is offline   Reply With Quote
Old 01-19-2012, 08:06 PM   #2
Rewards Points: 14,026
Simple hire a pro concrete finisher, Let him know what you want.
It's a one shot deal. Your just not going to have the tools or know how to get this done. Once that truck shows up it's show time. There is no going back and fixing it.
Old 01-19-2012, 08:08 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
One of those dreaded compound drainage concrete pours.
Just form with the elevations as they need to be, and stake up 2x's out in the middle at the heights you need to skread to that you will pull after you skread and before you jitterbug it.
titanoman is offline   Reply With Quote
Old 01-20-2012, 09:24 AM   #4
Rewards Points: 117
Jitterbug?
It looks like two sections to be poured almost at the halfway point of 12 to 13' of the 28' length. Trying to keep the joint away from the middle of the back door. The slope down to the driveway is exaggerated too. I suppose I could just have it all slope toward the driveway and not worry about. I was just looking to have it not slope sideway too much when you step out of the door.
Old 01-20-2012, 09:56 AM   #5
Old School
Willie T's Avatar
Looks like a potential problem area on the "right" section. You DO NOT want to slope back toward your house if there is even the slightest chance of it receiving water.
Jitterbug: http://youtu.be/IOH7Etaj72s
Willie T
Old 01-20-2012, 10:42 AM   #6
Concrete & Masonry
Rewards Points: 620
I agree with Willie that the right side can be a problem, especially if the grade around the house isn't sufficient to shedding the water fast.
If you're pouring it all at one time, the joint doesn't necessarily need to be at the pitch change, and the pitch can also run on a diagnol if it help's soften teh transition. I will tell you that if you decide to pour it all togehter, you need to very careful you don't flatten the transition area with the bull float/etc... as that area can easily hold water.
jomama45 is offline   Reply With Quote
Using Hardi siding as form for concrete patio TCS-Austin Building & Construction 13 08-14-2011 10:35 AM
circular fire pit paver patio - what to use/how to slope durkpiet Landscaping & Lawn Care 0 05-27-2010 11:43 PM
Do I need to slope my concrete patio if I am covering it? diyintexas Building & Construction 2 09-29-2009 03:02 AM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 02:35 PM
calculating slope for patio cover epdave Carpentry 7 01-21-2009 10:22 AM
