Best Way To Fasten Wood Gusset - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 07:02 PM   #1
Rewards Points: 1,646
Best way to fasten wood gusset
I have a roof truss that I need to repair. I have added the 2x4 cut piece back with Simpson's metal mending plates (which I know is not good enough). So I sistered two ten foot 2x4 on each side, and now I have three 2x4s.
I glued the sisters to the middle piece using Loctite PL Premium construction adhesive, in addition I used 3" 10d nails from both sides spaced at every 4 to 6 inches.
I am wondering if this is enough, or should I drill 3/8" or 1/2" holes through all three pieces of wood and use bolts and nuts as well?
If bolts and nuts makes even a stronger repair what spacing is good? Every 12" or 18"?
miamicuse is offline   Reply With Quote
Old 02-16-2012, 08:25 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Depends on where the break is.
It could be stressed or just floating.
Picture?
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
mae-ling (02-16-2012)
Old 02-17-2012, 05:18 AM   #3
Rewards Points: 960
I approve your repair as it is.
cleveman is offline   Reply With Quote
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 07:46 AM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 12:42 PM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
