Old 04-28-2012, 06:57 PM   #1
Best way to fasten 1x2 furring strips to concrete block walls
Wondering what is the best way to fasten 1x2 PT furring strips to concrete block walls?
I think my preferred choice would be a Ramset gun shooting nails but I don't have one.
The existing furring strips done back in the 70s they used hard cut mason nails. How were those applied? Hand hammered in? That's too much work.
I am now using Tapcons, but I found that to be hit and miss. On the solid concrete tie beam, I drilled with the Tapcon bit and most times when the screws bottom out it spins and do not lock tight. After a few tries I figured out what happened. If I blow air in using those keyboard dusting canisters to clear the concrete dust inside the holes, the Tapcon bites well.
However on hollow blocks I am still struggling. Half the screw won't bit well when bottom out. Since these are furring strips I need the screw head flushed with the wood, so I am using the flat head philips Tapcon and not the hex head ones. I tried screwing to the web or ends of the blocks but still hits and misses.
Any tricks anyone care to share?
miamicuse is offline   Reply With Quote
Old 04-28-2012, 07:05 PM   #2
Ravenworks's Avatar
Construction adhesive plus the ramset you should be fine,try to shoot into the mortar joint and NOT into the block because it weakens them and you run the chance of other problems.
Ravenworks is offline   Reply With Quote
Old 04-28-2012, 07:42 PM   #3
Tom Struble's Avatar
these are my favorite wood- masonry anchors
http://www.sierraanchors.com/Nail-ins.html
Tom Struble is offline   Reply With Quote
Old 04-28-2012, 07:45 PM   #4
For this all you need to do is to pre-drill the hole and hammer it in?
Will it be flushed with the wood or will the nail head protrude out a little?
Old 04-28-2012, 08:12 PM   #5
yes,the nail head does not protrude from the fastener
Old 04-28-2012, 08:23 PM   #6
What type of construction adhesive? You mean something like LiquidNail or Gorilla glue?
Old 04-28-2012, 08:28 PM   #7
DIY Enthusiast
sublime2's Avatar
Keep in mind the wood needs to be PT if it will be in direct contact with the block.
sublime2 is offline   Reply With Quote
Old 04-29-2012, 10:36 AM   #8
we often have seen block masonry or brick masonry but I havenm't seen walls being prepared by copncrete and block masonry as well .
is there a way to do so if yes please let me know
hammadzfr is offline   Reply With Quote
Old 04-29-2012, 11:57 AM   #9
Ravenworks's Avatar
A general construction adhesive will do,liquid nails will work
Old 04-30-2012, 12:08 AM   #10
PL Premium concrete
mae-ling is offline   Reply With Quote
Old 05-02-2012, 01:12 AM   #11
Moderator
Any species wood will do with a vapor barrier at block/wood on the wall only, #7: http://publicecodes.citation.com/ico...9_3_sec017.htm
Or, without the v.b.:
NATURALLY DURABLE WOOD. The heartwood of the following species with the exception that an occasional piece with corner sapwood is permitted if 90 percent or more of the width of each side on which it occurs is heartwood. Decay resistant. Redwood, cedar, black locust and black walnut.Termite resistant. Alaska yellow cedar, redwood, Eastern red cedar and Western red cedar including all sapwood of Western red cedar.
P.t. still lets water through to your drywall unless you add a poly plastic or shield like Grace (or sill-sealer); http://www.greenbuildingadvisor.com/...-building-code
Gary
Clothes taking longer to dry?
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
concrete block house shower medalta Building & Construction 3 11-02-2011 06:16 AM
Wood panel to concrete block wall sgold33 Building & Construction 22 07-30-2011 12:14 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
