Best Way To Cut Installed Vertical Studs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2008, 06:10 PM   #1
Best way to cut installed vertical studs?
I am lowering the height of a raised bar that is attached to the kitchen countertop. I want it to be the same height as the rest of the counter top, which will all be tiled when done. So, I am in the process of cutting the supporting framing and drywall to the same height as the top of the kitchen cabinets.
Is there a way to cut the vertical studs perfectly square, 1.5 inches below where the drywall ends, so I don't have to mess with repairing drywall?
I need to cut them so I can attach a 2x6 which I will attach plywood to.
I am thinking there is not an easy way, so I will trim it with wood.
green650 is offline   Reply With Quote
Old 08-23-2008, 06:31 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Not sure I am following your whole plan. But, to answer the question related to cuuting the studs: If you are removing an area of drywall, then you can mark the stud using a square, and cut using a reciprocating saw. Just make sure that there are no pipes or electrical lines there.
- Build Well -
Old 08-23-2008, 06:33 PM   #3
Registered User
Termite's Avatar
A reciprocating saw could be used to follow a line where you want them cut. Problem is that you'll vibrate the wallboard quite a bit if you aren't careful. If you can get access with a circular saw, that is a good way to go.
Old 08-23-2008, 06:33 PM   #4
Whatamess
Get a Sawsall with a metal cutting blade and saw nails and all. Take your time and you can get it pretty straight.
Good luck. http://www.lowes.com/lowes/lkn?actio...4PK&lpage=none
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 09:12 AM
How difficult is it to learn to use metal studs? YerDugliness Building & Construction 7 08-18-2008 06:59 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 10:57 AM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
