Best Way To Cut Fiber Cement Shingles? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 06:40 AM   #1
Best way to cut fiber cement shingles?
As per my other thread, I'm putting up some fiber cement shingles to replace the original asbestos ones. I'll have to go around some windows, so I'm wondering what's the best way to cut the 90-degree angle that's needed for the corner of each window and/or boxes for outlets.
I've got power nippers, but they seen to mash the shingles (probably better for planks). I've also got everything from a jigsaw, rotatary tool, and even the old guillotine shingles cutters.
Can I just use the jigsaw with carbide blades? I know that dust is a concern.
Scott99999 is offline   Reply With Quote
Old 06-15-2009, 07:14 AM   #2
RippySkippy's Avatar
Yes the dust is a PITA...and you need to protect your self. A couple of things I've used to cut Hardi shingles is a diamond cement blade in a 4" angle grinder and a Rotozip with a tile or drywall bit. For straight cuts I prefer the angle grinder. And yes the dust is horrible...but the cut is fantastic. I usually take a small piece of cut-off and rub along each side of the cut to remove the fuzz.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
RippySkippy is offline   Reply With Quote
Siding Options Vinyl vs. Fiber Cement obrien11j Building & Construction 35 09-26-2011 05:08 PM
Primed fiber cement siding and water/rain Scott99999 Building & Construction 2 06-13-2009 08:53 AM
Fiber Cement Siding pampie General DIY Discussions 10 03-02-2009 01:00 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
