******BEST Way To Cut An Existing Stone Veneer Fireplace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2012, 02:34 PM   #1
******BEST way to cut an existing stone veneer fireplace
I'm installing a new TV on a stone veneer fireplace. I need a 4" x 4" hole for electric ,etc.
What is the best way to cut the stone veneer?
...I was thinking a diamond blade on an angle grinder?
cuts225 is offline   Reply With Quote
Old 11-25-2012, 02:45 PM   #2
DIY staff
Rewards Points: 7,174
I would use that---how thick is the veneer and what's behind it?
Old 11-25-2012, 03:16 PM   #3
Too Short? Cut it Again!
Since you cannot go into the wall to brace, you need to be sure you are going to be on a stud when you get your hole made.
Old 11-25-2012, 03:20 PM   #4
Concrete & Masonry
Rewards Points: 636
Full veneer or thin veneer stone?? Thin is going to be far easier........
jomama45 is online now   Reply With Quote
Old 11-25-2012, 06:23 PM   #5
its thin ~1in, just cement board behind it
i can get behind the wall, thru the attic
what if i drill pilot holes all around and then use a chisel?
Old 11-26-2012, 06:44 AM   #6
Rewards Points: 3,130
[quote=cuts225;1060250what if i drill pilot holes all around and then use a chisel?[/quote]
I would use an angle grinder. Much faster.
Old 11-26-2012, 06:45 AM   #7
Deleted - duplicate post.
Old 11-26-2012, 06:48 AM   #8
Rewards Points: 1,216
I wonder if multi tool makes a blade that would plunge through that slowly.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-26-2012, 07:52 AM   #9
My Fein came with a blade I never used that is supposed to be for such things. I still think a masonry or diamond blade on a grinder would be faster.
If you drill holes make sure you have a masonry/stone bit. Pilot holes and cold chisels have been used for millenia even to quarry stone so the schema will certainly work. I still think an grinder will be faster? If you don't have one they are not outrageously expensive. I am surprised how often I used a grinder once I got one ages ago.
Of course I used the multi-tool almost every day bought you would want one like a Fein or of similar quality to take on stone. I don't know if the Harbor Frieght type equivalents would hold up.
Old 11-26-2012, 08:18 AM   #10
kwikfishron's Avatar
Rewards Points: 1,016
With just one hole to install a TV Iíd do it the old fashion way.
Sure a grinder is fast but Mama isnít going to like that cloud of dust thatís going to coat everything in that room and likely more.
Iím sure the multi-tool would work better for dust control but It doesnít make sense to purchase or rent one just for one hole.
kwikfishron is online now   Reply With Quote
Old 11-26-2012, 08:24 PM   #11
Concrete & Masonry
Rewards Points: 636
I wouldn't recommend using anything but a diamond blade and some sort of saw/grinder for what you're attempting to do. Thin stone doesn't do well with chiselling/vibration, and attempting to do so on tile backer board is bound to loosen/crack far more stone & joints than you intended. Just cut it and have someone hold a vacuum at the discharge of the grinder, or expect to remove alot more stone and mortar, and repair...............
Best Adhesive for Stone Veneer on Exterior Surfaces? JulieMor Concrete, Stone & Masonry 15 05-30-2012 11:24 AM
Veneer stone over stucco jsumb82 Concrete, Stone & Masonry 2 05-10-2012 06:08 PM
Fireplace w/ TV focus point. Stone to ceiling or not? POLL 6fthook Interior Decorating 2 05-25-2011 09:02 PM
Stone veneer over painted block Daystepper Building & Construction 0 09-16-2010 04:03 PM
Replacing slate with stone on a fireplace Debbiesue Building & Construction 4 09-04-2009 04:58 PM
