Best Way To Cover A 14' Span? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 01:39 AM   #1
Question
Best way to cover a 14' span?
I am building a 14'x5'4" loft room in my living room. It will be anchored on 3 sides by support walls.
The open end is 14' across. I plan on putting a long beam in a BIG Simpson hanger on each end.
What's the best wooden way to span that distance?
I have been told that sistering 2 2x10's (fir) with a strip of plywood glued and screwed between them is the way to go.
Is this better than using a fir 4x10x16 cut down to 14'?
thomaszr is offline   Reply With Quote
Old 01-29-2011, 05:35 AM   #2
DIY staff
Rewards Points: 7,174
Can you post a sketch of what you are trying to do?
I don't think you are trying to do anything to difficult--I don't have a span chart handy--one of the framers will,however.--Mike--
Old 01-29-2011, 03:25 PM   #3
sketch attached
as requested
Old 01-29-2011, 04:41 PM   #4
Carpenter
dtsman's Avatar
Engineered lumber, like they use over a 2 car garage door.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 01-29-2011, 05:43 PM   #5
What weight is it expected to hold?
mrgins is offline   Reply With Quote
Old 01-29-2011, 08:48 PM   #6
I'm not sure how much weight it will hold. Only for maybe 2 people and a desk. It's going to be small den/computer/man cave.
Old 01-29-2011, 08:58 PM   #7
Experienced
Jackofall1's Avatar
You will get many responses to this I am sure, a wise piece of advice, is to consult with an engineer, do a hand sketch, take it to a design house/engineer and have them review it, might be the best $100 bucks you ever spend.
I say this based on your last response, you don't know how much weight, there are minimums you must follow to meet building codes.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Gary in WA (01-29-2011)
Old 01-29-2011, 10:51 PM   #8
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
I wouldn't do the expensive beam, I would ledger three sides with 2 x 10s then hang 10" hangers off the short ends and install 2 x 10 the long way with a double 2x 10 and hangers on the out side edge.
You are within the span tables for residential sleeping areas with 30 lb. live with #2 DF.
Andy.
AndyGump is offline   Reply With Quote
The Following 2 Users Say Thank You to AndyGump For This Useful Post:
fungku (01-30-2011), oh'mike (01-30-2011)
Old 01-30-2011, 12:08 AM   #9
Contractor - Renovations
fungku's Avatar
If you were in Canada:
  • 4-2x10 SPF No.1&2 can span 14'-1"
  • 3-2x12 SPF No.1&2 can span 14'-11"
Built-up beams are fine for a dropped beam, but for a flush beam consider using engineered lumber, like an LVL. Some lumberyards can spec for you.
edit: didn't read Gump's post. AndyGump's way could be cheaper and easier.
fungku is offline   Reply With Quote
Old 01-30-2011, 07:25 AM   #10
Have you in investigated "box beams"? I have used them and they are quite strong --- and light. Check it out.
amen2u is offline   Reply With Quote
Old 01-30-2011, 12:25 PM   #11
I am in Hawaii and will be using FIR.
Is there any advantage to sandwiching a glued and screwed strip of ply between the 2 2x10's?
I've been told the criss cross grain adds some additional strength and helps prevent bowing.
Old 01-30-2011, 01:01 PM   #12
Plywood sandwiches will add more stiffness than strength but thats good in this case. I think an engineered wood beam would also be good and give you the choice of direction for the other joists.
As far as weight, allow for 40# live load and 10# dead load for the kind of use you mentioned. Thats per square foot btw
Old 02-02-2011, 12:53 AM   #13
Honestly- can you spare roughly 3in lower? IF you can do it out of 2x12 you can glue a piece of ply but not needed. A doubled up 2x12 then hangers will hold that any day of the week. You can still run your 2x10 joist just make the ledger on the outside 2x12
proremodel is offline   Reply With Quote
Tags
doubting thomas am i!
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 06:50 AM
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 12:17 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
Patio Cover Design Questions MrBill Building & Construction 3 06-09-2009 10:34 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
