Best Way To Attach Wooden Girders To Concrete Piers? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 10:51 AM   #1
Best way to attach wooden girders to concrete piers?
Hi,
A simple (I presume) question here:
What is the best way to attach wooden members to poured concrete piers? I know I could use a steel fasteners, called a Post Base (I think). I also know I could put a J-Bolt in the pier, put down a layer or two of roofing felt, and then bolt down a scrap of pressure treated wood, of which on top of sits my girders.
Are there more options? What works best? Also, in the option you describe as working best, what are all the materials needed?
Will be doing this next week, so am trying to figure out soon.
Thank you all,
Dan
danf26 is offline   Reply With Quote
Old 05-19-2011, 12:24 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
gotta tell ya Dan....never heard of the scrap wood thing. Sounds kinda hacky. Use galvanized, stand off post bases.
Hammer drill, appropriate sized masonry bit, 1/2" wedge anchors and a wrench to tighten nuts.
12penny is offline   Reply With Quote
Old 05-19-2011, 09:36 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
Simpson Strong Tie makes all kinds of fasteners for this. Home Depot sells all there stuff. At least for what you need. It is easier to apply the j anchor bolt into the concrete while it is still wet rather than drill a hole into it later. You may not have a choice though
Millertyme is offline   Reply With Quote
Old 05-27-2011, 09:13 PM   #4
SO, with the Simpson Strong Ties, where two girders are meeting over the same pier, should I have two strong ties, each connected to the pier with separate bolts, to catch each one individually? Or do I have the butt ends meet in the middle of one of the ties?
Old 05-28-2011, 12:24 AM   #5
Rewards Points: 1,092
My GUESS is there are long "spanner ties" just for that. Check the Simpson web site and I bet you'll find just what you need.
Old 05-28-2011, 12:30 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What about a pocket cast into the piers? The girts would then rest on the concrete and could still be mechanically fastened to the piers also. This way no shifting in a mechanical fastener. Not sure what you are trying to build. A minimal drawing would be nice.
XXX
How do I attach wooden frames to brick wall? martinbudden General DIY Discussions 11 03-09-2011 08:54 AM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 07:52 AM
Best way to attach rails to 4x4 posts when building a wooden fence??? cocean Landscaping & Lawn Care 8 11-24-2010 07:00 PM
Concrete spurs for a wooden fence Drinthehouse Carpentry 2 09-11-2010 12:14 PM
Reinforce concrete piers? Neil_K Building & Construction 8 11-21-2004 07:53 PM
