#1 |
Best way to attach wood trim to stucco?
I have stucco house in San Diego and would like to add some wood trim around existing windows (aluminum frames). Is there a good way to do this without risking water penetration behind the stucco? Is glueing an option? I'm a decent woodworker, but have no construction experience.
#2 |
Moderator
I'd really suggest avoiding doing this. When stucco is installed, any trim boards that the home is intended to have are already in place and the stucco is flashed/butted to the trim. The trim is never installed after the stucco. Too many chances for rotting trim since your drainage plane is the face of the stucco.
If you insist on doing it I'd recommend not penetrating the stucco in any way, even if you use silicone to seal the penetrations. Its just asking for problems. |
| Display Modes | |
| OSB Stronger than Plywood? | Weathermaker01 | Flooring | 15 | 12-22-2012 10:06 AM |
| Ready to paint the porch! Oil or latex? | Leah Frances | Painting | 8 | 07-26-2011 08:29 PM |
| white trim vs. wood stained | nwalford | Interior Decorating | 17 | 02-28-2011 03:54 AM |
| Removing latex paint from wood trim | ulbass | Painting | 1 | 03-12-2009 02:19 PM |
| Tile with a wood trim? | trick29392 | Flooring | 3 | 06-26-2008 08:19 AM |
