-   -   Best way to attach wood trim to stucco? (http://www.diychatroom.com/f19/best-way-attach-wood-trim-stucco-45166/)
maxcattum 05-24-2009 05:55 PM
I have stucco house in San Diego and would like to add some wood trim around existing windows (aluminum frames). Is there a good way to do this without risking water penetration behind the stucco? Is glueing an option? I'm a decent woodworker, but have no construction experience. :eek:
Termite 05-24-2009 10:52 PM
I'd really suggest avoiding doing this. When stucco is installed, any trim boards that the home is intended to have are already in place and the stucco is flashed/butted to the trim. The trim is never installed after the stucco. Too many chances for rotting trim since your drainage plane is the face of the stucco.
If you insist on doing it I'd recommend not penetrating the stucco in any way, even if you use silicone to seal the penetrations. Its just asking for problems.
maxcattum 05-25-2009 12:05 AM
Thanks, Termite -I guess I was hoping for some miracle solution. Glueing seems prone to failure and hard to do a quality job with, so I guess I'll stick with my plain stucco look. :thumbsup:
