Old 03-09-2010, 06:39 PM   #1
Best way to attach sheetrock to concrete foundation
Hello! I need to replace my wood stairs going to the basement. The stairs are inbetween the concrete foundation and a 2X4 wall; so theres a width limitation. the house was built in 56' and the foundation wall (and old sheetrock) shows no signs of mildew, mold, or moisture and is extremely hard. Whats the best way to attach to the stringers and sheetrock to the foundation?
Thank you!
Doityourself44 is offline   Reply With Quote
Old 03-09-2010, 06:45 PM   #2
Military Mom of 4
Snav's Avatar
Sheet rock has to attach into wood.
So for application on a cement/brick wall you would attach furring strips to the surface - and then attach the drywall to the furring strips.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
The Following User Says Thank You to Snav For This Useful Post:
Doityourself44 (03-09-2010)
Old 03-09-2010, 07:09 PM   #3
Super Moderator
The 'dot and dab' method works--Put liquid nails on the back of the sheet--Heavy bead all around the outside edge,Then 'Dots'-heavy globs about a foot apart.
Short cement nails ( 1') can be used to hold it in place till the glue dries. Some times simple wedging the sheets in place with some scrap wood will work.(I like the nails)
--Mike--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Doityourself44 (03-09-2010), jlhaslip (03-09-2010)
Old 03-09-2010, 07:19 PM   #4
Xtreme DIY'r
Your old sheetrock is probably not the same as what we buy today
Today's stuff may not hold up
Old 03-09-2010, 08:37 PM   #5
Any suggestions on attaching the stringers?
Old 03-09-2010, 08:39 PM   #6
What would use suggest based on my picture?
Old 03-09-2010, 10:55 PM   #7
Moderator
Termite's Avatar
No need to attach the stair stringer to the concrete. It can span top to bottom with no problem. If you want to, wedge anchors would be my suggestion.
Personally I think it is very poor practice to attach gypsum wallboard directly to concrete. That's just asking for all sorts of problems down the road. You're better off furring the wall out just enough to facilitate attachment. The furring strips could be wood or even steel resilient channel.
Old 04-29-2010, 12:50 PM   #8
I have the same exact situation. I'm thinking of attaching a moisture barrier and then concrete board instead of drywall. Will that work? if so, what should I use as a moisture barrier? I was thinking of either 6mil plastic or tar paper, but am open to suggestions.
GCDC is offline   Reply With Quote
? RE:Replacing exterior brick with LP lap siding on a poured concrete foundation Greg D Building & Construction 0 11-26-2009 08:49 PM
stone foundation to block or concrete Suzuki91vx800 Building & Construction 6 06-21-2009 04:34 AM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 07:28 AM
Sealing a concrete wall foundation richvoice Building & Construction 7 11-25-2008 03:55 PM
concrete foundation with a crawl space agrenvik Building & Construction 1 03-25-2008 09:27 PM
