Best Way To Attach A Rafter To A Ledger Board? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 09:11 AM   #1
Landlord
Rewards Points: 89
Best way to attach a rafter to a ledger board?
I'm building a lean-to on the back of the house and I can't figure out the best way to attach a rafter to the ledger. It's at an angle, so can you use joist hangers? I drew up a little pic of the situation.
cocean is offline   Reply With Quote
Old 06-27-2010, 11:44 AM   #2
use a joist hanger and cut a kerf into the rafter at 90 degrees to the ledger
Marbledust is offline   Reply With Quote
Old 06-27-2010, 11:52 AM   #3
Landlord
Rewards Points: 89
Thanks for answering, I actually thought of that about 5 min ago
Old 06-27-2010, 12:28 PM   #4
Rewards Points: 392
I would think that simpson makes some kind of metal fastener for that. I would also think that some kind of metal angle on each side would work, too.
rustyjames is offline   Reply With Quote
Old 06-27-2010, 12:45 PM   #5
simpsons makes right angle framing brackets, but the best and most coste effective would be to use solid blocking between each rafter
mark2007 is offline   Reply With Quote
Old 06-27-2010, 01:04 PM   #6
Registered User
Rewards Points: 4,920
Use a positive connection like Simpson for the pull-away resistance they give. Solid blocking around here is no longer accepted by code because of their failure rate. If a large lean-to, a LUS hanger may be required or steel strapping. (L = solid lumber, U = "U" shape, S = shear) http://www.strongtie.com/products/co...ace_ss-df1.asp
Be safe, Gary
Old 06-27-2010, 01:18 PM   #7
Landlord
Rewards Points: 89
What do you mean by solid blocking? This lean-to is only about 8 feet long and 6 ft wide. Big enough for a riding lawn mower, but it will be a way to get on the roof.
Old 06-27-2010, 01:48 PM   #8
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Could you just crossnail from the sides, or is that considered bad practice nowdays?
Old 06-27-2010, 05:03 PM   #9
Landlord
Rewards Points: 89
this is the way i'm doing it.....anybody think this is not right?
Old 06-27-2010, 05:10 PM   #10
concretemasonry's Avatar
Rewards Points: 2,570
What do you plan to do about moisture leakage in the area of the ledger? - Flashing under the moisture resistant wrap or what?
It seems bad if a tiny shed could cause $10,000+ damage from mold and rot.
Dick
concretemasonry is online now   Reply With Quote
Old 06-27-2010, 05:35 PM   #11
Landlord
Rewards Points: 89
This is just a small lean-to against a brick wall on my parent's mountain house. The lean-to will be under the eave
Old 06-27-2010, 05:55 PM   #12
Registered User
Ah... snow load. Rest the rafter on the heel, not the toe (or hanger the heel). Page #38, fig. #19: http://books.google.com/books?id=iwS...rafter&f=false
Be safe, Gary
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 03:53 PM
Ledger Board Mounting Wildie Building & Construction 6 04-04-2009 11:02 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 10:16 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
