Best Way To Affix 2" Foam Board Insulation To Foundation Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-20-2008, 09:18 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Best way to affix 2" foam board insulation to foundation wall
I'm just curious. What do the pro's think is the best way to attach rigid foam insulation boards to a concrete foundation wall?
TIA and TTFN,
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 07-20-2008, 09:49 PM   #2
Rewards Points: 2,906
I'm not a pro, but around where I live, they use stick clips. A stick clip has a base that you bond to the foundation wall and a pin that sticks out. You impale the insulation onto those pins and then push the washers onto those pins to hold the insulation in place.
Nestor_Kelebay is offline   Reply With Quote
Old 07-21-2008, 12:13 AM   #3
Be green & save green
actually the best way is to hire someone to hold it in palce forever
mgsproperties is offline   Reply With Quote
Old 07-21-2008, 12:52 AM   #4
Dam. Why couldn't I think of that.
Old 07-21-2008, 04:35 AM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
NESTOR IS CORRECT HERE IS A LINK THAT MIGHT HELP http://www.midwestfasteners.com/prod...on-hangers.php
Old 07-21-2008, 06:27 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You can also use a polurethane Construction adhesive.
- Build Well -
Old 07-21-2008, 06:43 AM   #7
Whatamess
If you just want ad space pay for it and don't waste our time. This site is for constructive advise. Yours wasn't
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 07-21-2008, 07:01 AM   #8
?? huh?
- Build Well -
Old 07-21-2008, 07:36 AM   #9
Whatamess
I was writing about mgsproperties post
Old 07-21-2008, 07:51 AM   #10
They make special adhesive for foam board that I have seen magazine articles recommend it. They say to use horizontal lines of glue the width of the boards.
I like the idea of stick clips. If you ever had mice or bugs get behind the foam, you could pull off the foam board.
PerpetuallyRepairing is offline   Reply With Quote
Old 07-21-2008, 08:30 AM   #11
Another DIY Zombie
Rewards Points: 264
I have used Adhesive in the past with good results.....
I do like the idea of the pins though!
javan is offline   Reply With Quote
Old 07-21-2008, 11:20 AM   #12
my guys ramset 'em on the foundation. Make sure to use a less powerful load and wide washer nails
dhag is offline   Reply With Quote
Old 07-21-2008, 11:50 AM   #13
Rewards Points: 392
Use the proper adhesive. I've experienced stripping foamboard off foundation walls that was attached with adhesive and I can verify it works very well.
rustyjames is offline   Reply With Quote
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 08:18 AM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
