-   -   Best way to affix 2" foam board insulation to foundation wall (http://www.diychatroom.com/f19/best-way-affix-2-foam-board-insulation-foundation-wall-23996/)
BigJimmy 07-20-2008 09:18 PM
I'm just curious. What do the pro's think is the best way to attach rigid foam insulation boards to a concrete foundation wall?
TIA and TTFN,
Jimmy
Nestor_Kelebay 07-20-2008 09:49 PM
I'm not a pro, but around where I live, they use stick clips. A stick clip has a base that you bond to the foundation wall and a pin that sticks out. You impale the insulation onto those pins and then push the washers onto those pins to hold the insulation in place.
mgsproperties 07-21-2008 12:13 AM
actually the best way is to hire someone to hold it in palce forever
Nestor_Kelebay 07-21-2008 12:52 AM
Dam. Why couldn't I think of that. :mad:
buletbob 07-21-2008 04:35 AM
NESTOR IS CORRECT HERE IS A LINK THAT MIGHT HELP http://www.midwestfasteners.com/prod...on-hangers.php
AtlanticWBConst. 07-21-2008 06:27 AM
You can also use a polurethane Construction adhesive.
TazinCR 07-21-2008 06:43 AM
If you just want ad space pay for it and don't waste our time. This site is for constructive advise. Yours wasn't
AtlanticWBConst. 07-21-2008 07:01 AM
?:huh:? huh?
TazinCR 07-21-2008 07:36 AM
I was writing about mgsproperties post
PerpetuallyRepairing 07-21-2008 07:51 AM
They make special adhesive for foam board that I have seen magazine articles recommend it. They say to use horizontal lines of glue the width of the boards.
I like the idea of stick clips. If you ever had mice or bugs get behind the foam, you could pull off the foam board.
javan 07-21-2008 08:30 AM
I have used Adhesive in the past with good results.....
I do like the idea of the pins though!
dhag 07-21-2008 11:20 AM
my guys ramset 'em on the foundation. Make sure to use a less powerful load and wide washer nails
rustyjames 07-21-2008 11:50 AM
Use the proper adhesive. I've experienced stripping foamboard off foundation walls that was attached with adhesive and I can verify it works very well.
