Best Water Repellent Treatments For Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-21-2008, 12:50 AM   #1
Best Water Repellent Treatments for Concrete
I will be building a deck over a concrete patio and I am planning to seal the concrete before starting the project.
I would be interested in hearing product recommendations and/or products to stay clear of.
Thanks!
redhermes is offline   Reply With Quote
Old 06-21-2008, 05:30 AM   #2
since conc appearance isn't prime concern, any silicone siloxane would be good for this,,, possible an apron store has it but prosoco/sonneborn/euclid're better suppliers,,, const supply houses're best source.
yesitsconcrete is offline   Reply With Quote
Old 06-24-2008, 09:35 AM   #3
Bad Advice???
First, thanks for the suggestion for siloxane.
I contacted my local dealer and he recommended using Prosoco SLX100. I looked at the SLX100 product data sheet online and it does not even appear to be siloxane. It is a silane-based product.
The second thing he told me is I could us it on the wood decking. Thatís not right is it?
Old 06-24-2008, 12:54 PM   #4
SLX-100 is overkill for what you want. Check out PROSOCO's Siloxane PD or Saltguard products.
Dorkgeez is offline   Reply With Quote
Tags
concrete
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
