Best Wall Material For Bar/club - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 06:00 PM   #1
best wall material for bar/club
Hey
long time reader, first time poster
I am doing some renos for a busy club and need some material to put up on the wall that has to be pretty much bulletproof. Drywall and paint just dont cut it. Currently theres particle board with melamine finish to it but its ugly as sin. I was thinking of putting up vinyl tiles or something on top of the melamine but its a little pricey.
Any ideas?
thanks
coyborgo is offline   Reply With Quote
Old 03-12-2011, 06:18 PM   #2
DIY staff
Rewards Points: 7,174
You are limiting this to 'cheaper than peal and stick tiles' ?
Corrugated steel barn siding? How cheap?
Old 03-12-2011, 06:49 PM   #3
In a little over my head
Rewards Points: 706
How about T-111?
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
oh'mike (03-12-2011)
Old 03-12-2011, 07:40 PM   #4
The best and most cost effective way of doing this is with USG FIBEROCK Aqua-Tough interior panels. I'm not talking the underlayment here. 5/8" will be very tough. You can double layer it and it will be pretty much bulletproof. Alternately you can use FIBEROCK Abuse-Resistant Panels. Use Durabond setting joint compound for first coat and Trim-Tex (I-beam) Corner beads. You can use DIAMOND Brand plaster if you need additional indentation resistance. But this stuff is pretty dent resistant as is.
Andre S is offline   Reply With Quote
Old 03-12-2011, 08:39 PM   #5
Not sure if it's relevant to your decision making process, but keep in mind that any materials that you put on the wall in a club (I'm going to assume we're talking nightclub/assembly use group) would need to pass a vertical flame spread test. Just because something sounds like it would be a good idea, doesn't make it so. Remember the Station Nightclub Fire in Rhode Island? Just food for thought.
wikkie650 is offline   Reply With Quote
The Following User Says Thank You to wikkie650 For This Useful Post:
Tags
wall material
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
70+ year old home with material on the wall booyay Carpentry 5 08-04-2009 06:18 PM
best material for shop wall covering? will52100 Building & Construction 7 02-20-2009 10:14 PM
