Best Type Of Wood For Studs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 08:35 PM   #1
Rewards Points: 174
Best type of wood for studs?
I did not realize that studs came in different types of woods. Any suggestion on the type to use for a basement remodeling?
Thanks.
Leoskee is offline   Reply With Quote
Old 07-25-2009, 09:10 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
You don't give your location. The types of wood studs available depends on your geographical area. Personally I've become a fan of metal studs.
http://www.thumbandhammer.com/diy/framing.html
Here is a video that makes it look easy:
http://video.bobvila.com/m/21320201/...ud-framing.htm
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-25-2009, 10:59 PM   #3
Registered User
Termite's Avatar
Depending on your location, your studs will probably be "stud" grade SPF (spruce/pine/fir) or southern yellow pine. You can get nicer grades than stud such as #2 or standard and better but you're not going to get straighter studs with higher grades, just less knots and wane. Hope for SPF and avoid SYP like the plague...Awful stuff to work with.
Old 07-26-2009, 02:24 PM   #4
Rewards Points: 174
Im in NJ. I was thinking about using metal studs but I was told that puting molding/chair rail will be a PITA. Any thoughts? Ive read on here that the price difference is not that big.
Old 07-26-2009, 02:46 PM   #5
Tool Geek
PaliBob's Avatar
Moldings & rails should not be a problem with self drilling trim screws.
http://www.mcfeelys.com/product/0715...osphate-Screws
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-26-2009, 08:59 PM   #6
Registered User
Termite's Avatar
Like Bob said, metal studs are fine if you don't mind using trim screws in your moulding. Personally I started out my career framing so I prefer wood, but do use metal on rare occasion. Metal makes things rather challenging for the average DIYer if you ask me.
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 01:42 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
Which type of wood is best for a privacy fence? ozarksjim Landscaping & Lawn Care 1 11-14-2008 02:38 PM
What type of wood to replace stair steps? darsunt Building & Construction 7 04-30-2008 01:22 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
