Best Tool For Cutting Metal Nail Plates - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2010, 04:23 AM   #1
Best tool for cutting metal nail plates
I am in the process of tearing down an old pool deck. The frame is connected using plates that have 4, 3 inch nails on each side. I am trying to salvage the lumber as it is still in great condition and I would like to save it for future projects. My question is would it be practial/quicker to use a Reciprocating Saw or angle grinder (or something else) to cut the plates at the seams? I tried using a pry bar but I was damaging the wood and it was impossible to use it in the corners. I'd say the metal plates are roughly 1/10 inch thick. Any help would be great.
Paul316 is offline   Reply With Quote
Old 08-28-2010, 05:33 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Paul, Welcome to the Forum
I am not sure of what your 'plates' look like with out a pic, But if they are anything like Reinforcing Angles, I would use a small Japanese style double ended Cat's Paw to pull the nails.
Here is an example of a Japanese Cat's Paw
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-28-2010, 09:05 AM   #3
Thank you for the reply Bob. I bought something very similar to what you suggested and it was very difficult removing the nails. Also very time consuming. The Angles you also posted are the ones i am trying to remove. There are also flat ones in the middle of the board.
Old 08-28-2010, 10:17 AM   #4
Tool Geek
PaliBob's Avatar
Originally Posted by Paul316 View Post
....... I bought something very similar to what you suggested and it was very difficult ........
Paul, If you bought a Cheap Cat's Paw that has a single end then you bought the wrong tool for your application. Cat's paws with a single end are great as a general purpose nail puller, but to get between the heads of nails and a steel plate, you need the small end of a Japanese style tool similar to Cat's Paws - Lee Valley Tools
* What does the tool you bought look like?
* Can you post a Pic of your reinforcing plates?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-28-2010, 12:48 PM   #5
Rewards Points: 1,016
Maybe try a SuperBar - often reached for in my tool bag for prying and nail pulling chores.
http://www.amazon.com/Vaughan-B215-1...ref=pd_cp_hi_1
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 03:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 11:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
power-actuated nail size for sole plates amakarevic Building & Construction 4 06-03-2008 02:12 PM
Tool to remove metal? darsunt Building & Construction 5 05-16-2008 04:01 PM
