Best Species Of Wood For T&G Porch Flooring? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2015, 11:53 PM   #1
Rewards Points: 54
Best species of wood for T&G porch flooring?
I will soon be replacing the tongue and groove porch flooring on my upper balcony and was wanting some opinions on the best species of wood to use for the T&G. I live in the south and so we get a lot of high humidity. So I'm looking for a species of T&G that can handle the high humidity rate as well as take paint well. Also if any of you could provide any tips for installing the T&G etc... I'd appreciate it. I want it to last! Sorry, I tried posting a picture but it's not letting me for some reason.
will04 is offline   Reply With Quote
Old 11-25-2015, 02:04 AM   #2
Rewards Points: 6,652
Any of the products like Trex is what is normally used. Less maintenance and stands up to all kinds of weather.
Old 11-25-2015, 02:24 AM   #3
Rewards Points: 54
Sorry should have mentioned this is a Recorded Texas Historical Landmark (RTHL), and will be required to stay with wood T&G.
Old 11-25-2015, 06:07 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
http://www.perennialwood.com/Product...rchBoards.aspx
Coastal South Carolina
Old 11-25-2015, 06:35 AM   #5
Rewards Points: 14,026
Any I've done where done with Fur.
Want it to last and not cup the trick is to seal it on all sides before installing.
I got lucky and found an old time real lumber yard that makes there own, 0 flaws, no knots, and they mill the grove wider so after applying the paint the wood still has room to expand and contract.
I use ceramic coated trim head screws using an impact driver to install it.
will04 (11-25-2015)
Old 11-25-2015, 10:41 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 590
Being in the south and in a historic district also, I personally would see if I could find some cypress and seal it like said above. I don't like pine, that is for sure.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
gregzoll (11-25-2015)
Old 11-25-2015, 11:29 AM   #7
Rewards Points: 332
Are they requiring wood or requiring T&G? I have a man made T&G on my porches and it looks great. Even at close range I haven't had anyone realize it wasn't wood. The stuff I used was called Tendura, but I believe it's Correct porch now. In the area I live many people are going with Mahongany. If this really is historical and they have requirements what are they? I would think they would tell you what wood to use if they are requiring that? AFAIK Fir is what was traditionally always used (in my area anyway) so to be true to historical correctness I would think that is the only choice?
KC_Jones is offline   Reply With Quote
The Following 2 Users Say Thank You to KC_Jones For This Useful Post:
gregzoll (11-25-2015), will04 (11-25-2015)
Old 11-25-2015, 12:17 PM   #8
Rewards Points: 54
KC I'll check in to that product thanks. It will just need to replicate what is there now, otherwise the THC will not approve it. Jim, I looked around online and there is a mill down the road from me in Austin that specializes in Cypress and mills T&G boards. Being that my house, a 1855 Greek Revival, is made of some cypress (beams and such) I'll check into that. Thanks for all the tips and help fellas
The Following 2 Users Say Thank You to will04 For This Useful Post:
BigJim (11-25-2015), gregzoll (11-25-2015)
Old 11-25-2015, 07:32 PM   #9
No location in your profile so we had to make a guess as to what wood would be avalible localy.
Cypress is a good choice would take me a month for me to get it and cost 4 times as much in my area.
Old 11-26-2015, 09:33 PM   #10
Rewards Points: 46
Will, I've done a few of the historic homes. Our Historic Society is very picky about the what and how of everything they can control. If you have that type of environment you might ask about 1x 4 Yellow Pine T&G flooring that is first primed with Boiled Linseed oil. Then once installed, painted with a Urethane type flooring finish. The key is the boiled linseed oil BEFORE the flooring is applied. It takes about 2 weeks for it to dry but it's the old timey way they did it when houses didn't have electricity or indoor plumbing. It's still used in historic areas as it works for preserving wood to the outdoors. Obviously the idea is to cut off any moisture or rain getting to the cells in the wood fiber. Regardless of the wood, cedar, cypress, pine, etc if it gets any water moisture to it, it will swell. If you've ever seen a porch floor that the wood is all cupped up, now you know.
Trapper6 is offline   Reply With Quote
About to order wood flooring deck hand Flooring 11 02-01-2013 02:47 PM
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 05:20 PM
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 05:57 AM
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 08:31 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
