Old 11-13-2012, 05:24 PM   #1
Which is best for sound proofing - 6lb / 8lb carpet pad, rubber pad, or cork underlay
Thank you in advance.
oodssoo is offline   Reply With Quote
Old 11-13-2012, 09:30 PM   #2
The only thing approved for laminate flooring underlayment in most condos in Chicagoland (for sound deadening for the tenants below) is cork. It is definitely better at sound control than carpet pad. Rubber pad, depends on the product.
Flooring installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating.
wewantutopia is offline   Reply With Quote
Old 11-13-2012, 09:48 PM   #3
In lieu of two layers of drywall, I am thinking about using cork as a sound insulator between the ceiling joists and drywall for the new basement buildout project. The space will be used for living space.
Old 11-14-2012, 08:23 AM   #4
Estimator & Draftsmen
CanAmGuy's Avatar
Regarding your comment on the ceiling application. you may find simple using resilient channel to suspend the drywall from the joist will provide adequate sound control at a fraction of the cost of putting cork on the joist. Another key factor is using a sound absorbing silicone at the joints and perimeter of the ceiling. The type of drywall you use can also be a factor. How much noise are you trying to eliminate? for example is it a game room or fitness room in the basement that you don't want the noise traveling to the room above.
CanAmGuy is offline   Reply With Quote
Old 11-14-2012, 09:16 AM   #5
Thanks for the comments thus far.
With regards to CanAmGuy's comment, primarily the basement area will be like an apartment (i.e. bedrooms, bathroom, kitchen, etc.). So, the thought of doing anything is to prevent sound from going up and down. So by definition, it would be sound insulation (???).
At any rate, for the drop ceiling vs drywall topic, we chose to go with the look that does not make it look like a basement.
The thought to add a layer of carpet pad material, rubber carpet pad, or cork in between the joist and the drywall is simply to stop sound from passing through onto the drywall.
QUESTION: Just curious though, where can I get this kind of drywall you are speaking of?
Old 11-14-2012, 09:18 AM   #6
Of your three proposed choices, cork would be the best for sound insulation.
The Following User Says Thank You to wewantutopia For This Useful Post:
oodssoo (11-14-2012)
Old 11-14-2012, 09:31 AM   #7
CanAmGuy's Avatar
Just to clarify, the method I was referring to is not suspended ceiling tiles. It will look just like your livingroom ceiling. In between the floor joist install a sound attenuation batt (acoustical insulation, unfaced).Then a RC-1 resilient channel is mounted running perpendicular to your floor joist. (it's like a furring strip). then your drywall is mounted to the resilient channel. at the butt joints of the drywall you want to use a silicone as well as around the perimeter. Make sure the drywall is not tight to the wall, leave a small gap (1/8") for the silicone. Then finishing taping, mudding and painting. That should give you an STC rating around 50
Old 11-14-2012, 09:53 AM   #8
CanAmGuy's Avatar
Here is another good sound absorbing product that we sell in frequently.http://www.homasote.com/Installation...ights_wall.pdf Homosote 440 Sound Barrier is easy to handle and depending on your area may be cheaper than cork.
Old 11-14-2012, 03:03 PM   #9
Came across this at Home Depot... Roberts AirGuard 100 sq. ft., 3.34 ft. x 30 ft. X .25 in. thick, Premium 3-in-1 Underlayment.
Has anyone used this product before? If so, what's your experience like?
Old 11-15-2012, 10:54 PM   #10
No one?
Old 11-16-2012, 08:48 AM   #11
That is the underlayment covered in EPS foam beads right? NOT a fan.
Pipe insulation: Foam, Rubber, Other? IckesTheSane Plumbing 36 10-29-2011 09:31 PM
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 08:04 AM
Rubber mulch Vs. Kids Carpet mulch for backyard play system whataboutj Landscaping & Lawn Care 1 04-26-2010 11:22 AM
Good equipment to use for carpet cleaning? Beth777 General Discussion 5 08-29-2008 09:16 PM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 09:35 AM
