Best Sealant For Window Frame - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 12:31 AM   #1
Rewards Points: 682
Best sealant for window frame
I am replacing deteriorated wood on parts of an exterior window frame. Sealing against moisture is critical of course. I was planning to use 100% silicone sealant for everything. Is there anything better?
darsunt is offline   Reply With Quote
Old 10-19-2011, 05:26 AM   #2
Framing Contractor
Rewards Points: 120
OSI Quad.
sixeightten is offline   Reply With Quote
Old 10-19-2011, 05:36 AM   #3
kwikfishron's Avatar
Rewards Points: 618
Agreed with the Quad. Vulkem is another choice. You want a polyurethane based caulk, not silicone.
kwikfishron is online now   Reply With Quote
Old 10-19-2011, 08:57 AM   #4
Rewards Points: 212
A comment from experience with polyurethane caulk/glue:
Wear gloves!
This stuff doesn't wash off with soap and water--- nor any other liquid I've tried. It will wear off as the skin wears off. Your hands will be like new in
10 -15 days.
Forewarned is forearmed.
Just my $.02
Good luck.
orange is offline   Reply With Quote
Old 10-19-2011, 09:31 AM   #5
Rewards Points: 5,336
What are you sealing? If you're replacing wood, you want to prime all sides before you install it. After it's installed, paint it with a high quality paint. The caulk you use should also be paintable.
Ron
B. Franklin 1759
Old 10-19-2011, 05:21 PM   #6
Rewards Points: 618
Cleans up nicely with mineral spirits.
It will wear off as the skin wears off. Your hands will be like new in 10 -15 days.
Only 2 or 3 days if you keep picking at it.
Old 10-19-2011, 05:54 PM   #7
Framing Contractor
Rewards Points: 120
If only I could get it off of my shirt and pants...
Old 10-20-2011, 07:44 AM   #8
Rewards Points: 2,238
Yeah!
If you don't hit it with Mineral Spirits - Right Away! - too late!
(Quad - Polyurethane, based - etc.)
Don't get it in your hair!
Clothes? - forget it!
(Part of your clothes, will be waterproof)
rossfingal
rossfingal is offline   Reply With Quote
Old 10-20-2011, 07:58 AM   #9
Rewards Points: 212
If you do it immediately. If it sets up at all, or if you get you hands wet with water, it's a whole new ball game.
I did some "googling" and found this set of posts. It is related to PL Premium, which is what I was using, but I think it applies to most polyurethane products.
http://billfitzmaurice.info/forum/vi...bd83dda055ac5e
Note: The latex gloves doesn't seem to be a popular solution.
Old 10-20-2011, 08:18 AM   #10
Polyurethane ("PL") works very well!
However; sticks to almost, everything!
(Sure does stick to me!)
rossfingal
Old 10-20-2011, 08:53 AM   #11
Rewards Points: 618
I always try to have a thinner soaked rag at my side when using the stuff.
If I have a lot of caulking to do at the end of the day I end up smelling like diesel fuel. Nice trade off for clean hands.
A painters clothes are covered in paint mine are covered in poly gack. What are you going to do? When you buy the stuff by the case thereís no way youíre not going to ware some of it.
Never could tool the stuff worth a $hit with gloves on. Canít roll nails fast enough with gloves either.
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
orange (10-20-2011), rossfingal (10-20-2011)
Old 10-20-2011, 09:02 AM   #12
Yeah! "kwiK"!
Carried MS Spirits - Lacquer Thinner - in my truck -
Never had enough time to use them!
(I'm 3 - 4 - 5 stories? - ain't getting down!)
rossfingal
("tooling" it with gloves - probably not!)
narrow frame dual pane windows tns1 Building & Construction 0 12-21-2010 02:05 PM
New window in old frame KurtP Building & Construction 0 09-12-2010 10:10 AM
exterior door frame size and rough opening kevincw01 Building & Construction 3 06-06-2010 08:26 AM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 09:09 PM
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 02:23 PM
