Best Replacement Facia - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2008, 08:40 AM   #1
Question
Best replacement Facia
I am in the Dallas area and on my home I am taking down the gutters and old facia and would like to know what is the best one to use beside Hardi. I want to be able to get 1'6 for Facia and 1x2 for the trim without having to rip it. What would you recommend and where in the Dallas FTW are can it be bought.
Bigbobdallas is offline   Reply With Quote
Old 06-18-2008, 10:45 AM   #2
I would use cedar for both the fascia and trim. You might be able to get the trim primed.
TexasEd is offline   Reply With Quote
Old 06-18-2008, 11:30 AM   #3
Why this type
What is the reason you would use the treated that would have to be painted over some other type, just curious.
Old 06-18-2008, 03:46 PM   #4
Registered User
Termite's Avatar
Your FASCIA is 1'6"??? That's a mighty wide fascia. No offense, but you sure you've got your terminology right? Fascia is usually 1x6 or 1x8. You won't find any solid-sawn material that wide, and if you did, it would be mighty unstable. You could use LP SmartTrim, but you'd have to use two pieces. You'd also want to backprime it. I think it comes in 16' lengths, but don't quote me on it.
Old 06-19-2008, 07:34 AM   #5
Hit wrong Keystroke
1"x 6"
Old 06-19-2008, 08:00 AM   #6
Registered User
Termite's Avatar
Gotcha! Stranger things have happened, so it was worth being sure!
I'd really suggest LP SmartTrim. It would be fairly cost effective, and it is a good product.
Old 06-19-2008, 12:09 PM   #7
Yeah, I assumed you meant 1x6" for the fascia.
I don't understand this question, but I think you are asking why I would get pre-primed trim. I assume you will be painting this new fascia to match the rest of the building. Having it primed when you buy it wont hurt.
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 03:50 PM
Replacing facia board mattflytx Carpentry 14 01-09-2008 08:50 PM
replacement compressor needed for old GE rotolock alex977 HVAC 1 05-17-2007 07:36 PM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 03:42 PM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 05:01 PM
