Best Product To Smooth Rough Concrete Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-11-2009, 10:55 AM   #1
Best product to smooth rough concrete wall?
I want to smooth a 3x8 section of rough concrete in my garage and then paint it. I don't have the tools to grind or sand it down. Would block filler work or do I need some kind of surface Binding Concrete to overlay it? any ideas would be welcome. Thanks.
jeff29715 is offline   Reply With Quote
Old 05-11-2009, 11:34 AM   #2
you can rent a grinder,,, not owning the right tools & trying to solve this will only lead to failure,,, paint is NOT a permanent solution to covering conc - eventually it'll fail.
yesitsconcrete is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Brace wall on concrete Base Elecman Building & Construction 6 10-30-2008 04:33 PM
Concrete Wall Structural Strength geiser Building & Construction 2 03-11-2008 10:09 AM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 09:20 AM
