Best Method To Sleeve Slab Penetrations - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-27-2007, 05:05 PM   #1
What is the best method to sleeve or protect plumbing and electrical conduit where it penetrates the slab, or is it even necessary with PVC?
jrepp is offline   Reply With Quote
Old 12-27-2007, 09:58 PM   #2
ICF Construction
All penetrations within concrete should be sleeved for several reasons, one being expansion and contraction of the pipe, second to allow for slight shifting of the slab or earth (hopefully it doesn't happen, but can!!!)
Either place a larger piece of pipe over the current one and pull out as the concrete starts setting, but before it cures as it is almost impossible to remove at that point, or wrap the pipes (1/2") with a sill gasket foam.
Chris
Chris Johnson is offline   Reply With Quote
Old 12-28-2007, 03:25 PM   #3
Rewards Points: 16
Chris...If you were to put a 1" peice of conduit in a slab and sleeve it with say a 2" peice of pvc, do you need to pull the larger pipe out or can you leave it in place? Just curious, thanks
ponch37300 is offline   Reply With Quote
Old 12-28-2007, 03:42 PM   #4
ICF Construction
I suppose you could leave it in, I always pull them out when we are on top finishing the slab, just give it a little wiggle and twist and up the come.
Chris
Old 12-28-2007, 06:02 PM   #5
General Contractor
joasis's Avatar
Our new construction gets 1-1/2 inch ABS plastic with large sweeps under the slab, then PEX ran inside of this...ever a problem, out it comes.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
