Best Method For Remortaring Joints - Block Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-28-2011, 03:31 PM   #1
Rewards Points: 264
best method for remortaring joints - block wall
walls were built in 1965. some of the vertical joints on 4" cinder block are separating. Old mortar needs to be removed and replaced. There are probably 10 places that need to be redone. I am talking about 8" tall so not too much but both sides of wall need to be fixed. So if I do the math I am talking about a total of 13 ft. What is the best method to do this? What is the best way to remove old grout?
Pawl is offline   Reply With Quote
Old 10-28-2011, 03:37 PM   #2
Rewards Points: 582
Can be done with an angle grinder, or lump hammer and plugging chisel.
stuart45 is offline   Reply With Quote
Old 10-28-2011, 04:07 PM   #3
concrete contractor
Pawl is right, an angle grinder works great. And the blades are fairly inexpensive. As for remortaring, I like to use a grout bag. It's looks the same as the frosting bags that cake decorators use. I get them at Home Depot and like places for about five bucks.
johnnyconcrete is offline   Reply With Quote
Old 10-28-2011, 06:47 PM   #4
Too Short? Cut it Again!
Tuckpointing restoration 101. See if the library has some guidebooks.
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 09:32 PM
Cement Block Wall Footing 99altrade Building & Construction 41 08-10-2011 12:39 PM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 10:58 PM
Mortar bed removal from block wall Douger_F Building & Construction 8 04-15-2009 07:47 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
